- 9
- 2003-11-17
I tried to rotate a solid impeller in a stationary fluid domain. What's I am trying to do is that the solid impeller rotates by itself and pushes the surrounding fluid.
The reason I need a solid domain instead of making a cutout from the fluid is that I actually want to do a conjugate heat transfer simulation.
I set the the solid impeller as a rotating domain, and the fluid as a stationary domain. And tried various options for the interface between solid and fluid. But none of them worked. It seems that the rotating solid impeller has no effect on the fluid flow.
Could anybody guide me? Thanks a lot. |
