- 2008-4-10
我建了一个模型,可是有很多的错误。
其中一个关键的是: 算出来负数的密度。ansys的提示是,关掉density,但是不知道怎么弄,帮助中也没有看到,不知道大家怎么弄的啊?
Negative density calculated. Solution terminated. This could be causedby a property error or a divergent solution. %/ %C:1 %I:2.
When this message occurs early in the solution, it probably meansthat the properties were specified incorrectly. When it occurs after a fewiterations, it probably means divergence (which could also be due to a badspecification). You can switch variable density OFFto allow any swings in the solution to stabilize, and then restart the analysis.
谢谢了。 |
