- 2008-4-30
ANSYS报错信息
*** ERROR *** CP = 189.650 TIME= 10:58:50
One or more elements have become highly distorted. Excessive
distortion of elements is usually a symptom indicating the need for
corrective action elsewhere. Try ramping the load up instead of step
applying the load (KBC,1). You may need to improve your mesh to
obtain elements with better aspect ratios. Also consider the behavior
of materials, contact pairs, and/or constraint equations. If this
message appears in the first iteration of first substep, be sure to
run shape checking of elements.
CFX的报错信息
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| CFX encountered the error: Read. Fatal error occurred when reque- |
| sting Total Mesh Displacement for FSI.
我做的是一个关于微泵的固液耦合
设置的时间步很小
MFTI,1e-006
MFDT,1e-009,1e-009,1e-009,OFF
出错时计算了7个时间步
会不会是因为应变速率太大,引起了塑性应变,而我在材料里没有设置塑性数据?
载荷是通过imprint face引入的压强,是不是imprint face在划分网格时成为了另外一种表面单元?需不需要对这个表面单元有其他的操作?
网格是自动生成的,没有控制参数
请问大家问题大概出在哪里,我应该从哪方面着手,
我自己觉得是跟时间步太小有关系,因为我尝试计算了下时间步是秒时,没有出现问题。 |
