- 2010-3-7
在安装abaqus6.9后,在运行作业时出现下列错误提示:The excutable
E:\SIMULIA\6.9-2\exec\standard.exe aborted with system error code 144. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
查看
http://forum.simwe.com/archiver/tid-744816.html
等相关帖子,整了两天没整出来。回想安装过程中只有一个疑问:在安装product时出现
Command line option syntax error.Type Command/?for Help百度一下,有网友说“
如果不是这个学习软件本的问题!就是这个软件不支持这种系统! 要么就是你的XP缺少某个文件! ”
不知出现error code 144的错误提示是否和
安装中出现的错误command line option syntax error,type command/? for help有关?又该怎么调试呢?希望得到各位前辈的指导!谢谢! |
