- 2008-12-18
*dim,horizon,array,1,50
*dim,vertical,array,1,50
*create,anti
*vread,horizon(1),horizon,txt,,ijk,1,50
(f5.2)
*end
/input,anti
*create,anti
*vread,vertical(1),vertical,txt,,ijk,1,50
(f5.2)
*end
用*status,horizon 查看读入数据后的数组horizon,结果如下:
PARAMETER STATUS- HORIZON ( 17 PARAMETERS DEFINED)
(INCLUDING 15 INTERNAL PARAMETERS)
LOCATION VALUE
1 1 1 -1.08000000
1 2 1 -1.01000000
1 3 1 -8.83000000
1 4 1 -9.52000000
1 5 1 -1.20000000
1 6 1 -1.42000000
1 7 1 -1.28000000
1 8 1 -1.10000000
1 9 1 -8.51000000
1 10 1 -8.50000000
1 11 1 -1.31000000
1 12 1 -1.76000000
1 13 1 -1.93000000
1 14 1 -1.62000000
1 15 1 -1.44000000
1 16 1 -1.08000000
1 17 1 -8.18000000
1 18 1 -4.16000000
1 19 1 -6.54000000
1 20 1 -1.30000000
1 21 1 -1.90000000
LOCATION VALUE
1 22 1 -1.95000000
1 23 1 -6.54000000
1 24 1 3.05000000
1 25 1 1.41000000
1 26 1 -4.88000000
1 27 1 -1.28000000
1 28 1 -1.44000000
1 29 1 -2.02000000
1 30 1 -2.60000000
1 31 1 -3.25000000
1 32 1 -3.06000000
1 33 1 -1.72000000
1 34 1 -1.97000000
1 35 1 -1.63000000
1 36 1 -1.64000000
1 37 1 -6.64000000
1 38 1 2.51000000
1 39 1 1.50000000
1 40 1 2.36000000
1 41 1 2.52000000
1 42 1 3.36000000
LOCATION VALUE
1 43 1 4.64000000
1 44 1 4.92000000
1 45 1 4.19000000
1 46 1 3.59000000
1 47 1 2.71000000
1 48 1 2.35000000
1 49 1 3.40000000
1 50 1 1.13000000
怎么那么多0?是不是standard FORTRAN real format 的问题?
(f5.2)中f后面的5.2是什么意思?
求standard FORTRAN real format 说明。
horizon.txt文件的数据如下:
-1.08E+01
-1.01E+01
-8.83E+00
-9.52E+00
-1.20E+01
-1.42E+01
-1.28E+01
-1.10E+01
-8.51E+00
-8.50E+00
-1.31E+01
-1.76E+01
-1.93E+01
-1.62E+01
-1.44E+01
-1.08E+01
-8.18E+00
-4.16E+00
-6.54E+00
-1.30E+01
-1.90E+01
-1.95E+01
-6.54E+00
3.05E+00
1.41E+01
-4.88E+00
-1.28E+01
-1.44E+01
-2.02E+01
-2.60E+01
-3.25E+01
-3.06E+01
-1.72E+01
-1.97E+01
-1.63E+01
-1.64E+01
-6.64E+00
2.51E+00
1.50E+01
2.36E+01
2.52E+01
3.36E+01
4.64E+01
4.92E+01
4.19E+01
3.59E+01
2.71E+01
2.35E+01
3.40E+01
1.13E+01 |
