查看: 30|回复: 0
[警告错误信息] 求助:缺失箍筋的属性属性!急急急
发表于 2010-5-25 19:25:25 | 显示全部楼层 |阅读模式 来自 辽宁沈阳
我在提交作业后,出现以下错误:***ERROR: ELEMENT 1 INSTANCE GUJIN-1 IS MISSING A BEAM SECTION DEFINITION;
           CHECK ELEMENT SET AND ELEMENT DEFINITIONS
***NOTE: DUE TO AN INPUT ERROR THE ANALYSIS PRE-PROCESSOR HAS BEEN UNABLE TO
          INTERPRET SOME DATA.  SUBSEQUENT ERRORS MAY BE CAUSED BY THIS OMISSION
***WARNING: ONLY A BEAM SECTION PROPERTY OPTION MAY BE USED WITH ELEMENT 2
             INSTANCE GUJIN-1. CHECK THAT NO OTHER PROPERTY REFERS TO THIS   ELEMENT.
望各位高手多多指教!
GMT+8, 2024-6-26 14:39 , Processed in 0.047733 second(s), 13 queries , Gzip On, MemCache On.
