- 2005-7-10
刚才那个没发成功,请斑竹删除,谢了。
模拟单轴压缩条件,一提交工作就144了。错误信息如下,请各位分析一下.inp文件和umat文件见压缩包。谢谢各位了.# f' g( r+ T" Y. z. Z! y8 f4 [
Traceback (most recent call last):# W9 p" |2 B1 g5 Q- p+ Q1 O- }
File "python/monitorMechanism.py", line 287, in read
) p* m. q$ f" D* Nerror: (10054, 'Connection reset by peer')- A$ d' O9 Z$ \$ `2 _8 m) z% @
Error in job 072916-3: The executable D:\ABAQUS\6.6-1\exec\standard.exe aborted with system error code 144. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run ABAQUS that you used when the problem occurred. Please contact your local ABAQUS support office and send them the input file, the file support.log which you just created, the executable name, and the error code.- j7 `1 t- ?. u! q6 ~& [: S7 v
Job Job-1 aborted due to errors. |
