- 2009-10-15
以下就是我的程序,请各位看看:存在一个问题,在加了壳单元的情况下,整个地表是向上隆起的,请多多指教!!
gen zone radcyl p0 0 0 0 p1 6.5 0 0 p2 0 5 0 p3 0 0 6.5 dim 3.1 3.1 3.1 3.1 size 3 5 12 3 ratio 1 1 1 1 group tutl fill group suidao
gen zone reflect normal 0 0 -1
gen zone brick p0 6.5 0 -6.5 p1 add 18 0 0 p2 add 0 5 0 p3 add 0 0 13 size 18 5 12 group ytutl
gen zone brick p0 0 0 6.5 p1 add 6.5 0 0 p2 add 0 5 0 p3 add 0 0 7 size 6 5 7 group s-tutl-1
gen zone brick p0 6.5 0 6.5 p1 add 18 0 0 p2 add 0 5 0 p3 add 0 0 7 size 18 5 7 group s-tutl-1
gen zone brick p0 0 0 -20 p1 add 6.5 0 0 p2 add 0 5 0 p3 add 0 0 13.5 size 6 5 14 group x-tutl-1
gen zone brick p0 6.5 0 -20 p1 add 18 0 0 p2 add 0 5 0 p3 add 0 0 13.5 size 18 5 14 group x-tutl-1
model mohr
property bu 2.5e7 sh 7e6 fric 30 cohesion 2.1e4 tension 2e4
in de 1900
set gravity 0 0 -9.81
fix x range x 24.5
fix x range x 0
fix y range y 0
fix y range y 5
fix z range z -20
set mech ratio=1e-5
solve
save quan-moxing.sav
in xdisp=0 ydisp=0 zdisp=0
def excate_step1
n=1
a1=n-1
a2=n
end
excate_step1
mod null range cyl end1 0 a1 0 end2 0 a2 0 rad 3.1
sel shell id=1 range cyl end1 0 a1 0 end2 0 a2 0 rad 3.1 group suidao not
sel shell id=1 property iso=(3.45e10,0.3) thick=0.35 density 2450
set mech ratio=1e-5
solve
save section1.sav
def excate_step2
n=2
a1=n-1
a2=n
end
excate_step2
set mech ratio=1e-5
solve
save section2.sav
def excate_step3
n=3
a1=n-1
a2=n
end
excate_step3
set mech ratio=1e-5
solve
save section3.sav
def excate_step4
n=4
a1=n-1
a2=n
end
excate_step4
set mech ratio=1e-5
solve
save section4.sav
def excate_step5
n=5
a1=n-1
a2=n
end
excate_step5
set mech ratio=1e-5
solve
save section5.sav |
