查看: 43|回复: 0
[命令/FISH] 求助
发表于 2010-7-10 13:25:40 | 显示全部楼层 |阅读模式 来自 山东青岛
;非全长锚固、预紧力锚杆(锚索)模拟
;方法1、通过删除-建立link链接来模拟托盘
gen zone radtun  p0 0,0,0   p1 25,0,0  p2 0,50, 0  p3  0,0,25  size 4 25 4 10 dim 4 4 4 4 ratio 1 1 1 1.1  fill
gen  zone  reflect  normal  1 0 0  ori  0 0 0
gen  zone  reflect  normal  0 0 1  ori  0 0 0
mo mohr
pro   bulk  2.2e9  she  1.3e9  fric  30    coh  1.3e6  ten 1.5e5
ini dens 2000
fix x range x -25.1,-24.9
fix x range x 24.9 25.1
fix y range y 49.9 50.1
fix z range z -25.1 -24.9
fix z range z 24.9 25.1
sel cable id=1 beg  0, 0, 0   end 0 ,29, 0  nseg 10
sel cable id=1 beg  0,29,0  end 0,35,0 nseg 6
sel cable id=1 prop emod 2e10 ytension 310e3 xcarea 0.0004906 &
                    gr_coh 1 gr_k 1 gr_per 0.0785 range cid 1,10
                    gr_coh 10e5 gr_k 2e7 range cid 11,17
sel delete link range id 1
sel link id=100 1 target zone
sel link attach xdir=rigid ydir=rigid zdir=rigid xrdir=rigid yrdir=rigid zrdir=rigid range id 100
sel cable id=1 pretension 60e3 range cid 1,10
step 2000
sav 10-5.sav
蓝色部分怎么解释?谢谢!
GMT+8, 2024-9-25 18:30 , Processed in 0.035382 second(s), 12 queries , Gzip On, MemCache On.
