- 2010-7-15
在流固耦合 CFX运行solution时出现如下:
Ans.Core.Commands.UserReadableFailure: The CFX Solver for system Fluid Flow exited with an error. A results file is available.
Detailed information can be found in the output file for the run, which can be viewed by selecting Display Monitors from the Solution component.
at Ans.CFX.CFXCore.Data.CFXSolutionSource.ReconnectRun(CommandContext context, SolverBackgroundTask task)
at Ans.CFX.CFXCore.Data.CFXSolutionSource.RunSolver(CommandContext context, Boolean forceResume)
at Ans.CFX.CFXCore.Commands.UpdateSolutionCommand.Execute(CommandContext context)
at Ans.Core.Commands.Concurrency.CommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
at Ans.Core.Commands.Concurrency.BaseWorkUnit.doExecute(IExecutionEngineCallback executionEngine, CommandContext subContext)
at Ans.Core.Commands.Concurrency.BaseWorkUnit.Execute(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ans.Core.Commands.CommandFailedException: The CFX Solver for system Fluid Flow exited with an error. A results file is available.
Command: CFX.UpdateSolution(Container="Solution")
at Ans.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
at Ans.Core.Commands.CommandAsyncResult.Wait()
at Ans.ProjectSchematic.Data.ComponentTemplateEntity.Update(CommandContext context, IProgressMonitor progressMonitor, DataContainerReference container, List`1 downstream, List`1 allRemaining)
at Ans.ProjectSchematic.Update.UpdateImpl.updateCell(CommandContext context, UpdateTask task)
at Ans.ProjectSchematic.Update.UpdateImpl.<>c__DisplayClass19.<updateCellAndDependencies>b__18()
at Ans.ProjectSchematic.Update.UpdateImpl.executeWithSelectedErrorBehaviour(Op op, UpdateTask forTask)
at Ans.ProjectSchematic.Update.UpdateImpl.updateCellAndDependencies(UpdateTask task, Boolean& didSomething)
at Ans.ProjectSchematic.Update.UpdateImpl.checkAndUpdateCell(UpdateTask task, Boolean& didSomething)
at Ans.ProjectSchematic.Update.UpdateImpl.doOutstandingTasks(IEnumerable`1 tasks, Boolean& didSomething)
--- System.InvalidOperationException: Update of the Solution cell in Fluid Flow failed: The CFX Solver for system Fluid Flow exited with an error. A results file is available.
at Ans.ProjectSchematic.Update.UpdateImpl.<UpdateCells>d__3.MoveNext()
at Ans.ProjectSchematic.Commands.UpdateComponentCommand.<Execute>d__0.MoveNext()
at Ans.Core.Commands.Concurrency.SuspendableCommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
--- Ans.Core.Commands.CommandFailedException: Update of the Solution cell in Fluid Flow failed: The CFX Solver for system Fluid Flow exited with an error. A results file is available.
Command: UpdateComponent(Component="/Schematic/Component:Solution", Force=True)
at Ans.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete(Int32 milliSecondsTimeout, Boolean exitContext)
at Ans.CFX.CFXCore.Commands.UpdateFromSolverManagerGui.Invoke(GuiOperationContext context)
at Ans.UI.UIManager.<>c__DisplayClass9.<InvokeOperation>b__8()
at Ans.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages)
请问高手是什么问题啊? 设置应该对的啊。。。 |
