查看: 249|回复: 1
[断裂与失效] Define a mixed-mode cohesive law
发表于 2010-9-4 16:15:42 | 显示全部楼层 |阅读模式 来自 香港
I am using cohesive element in Abaqus/Standard to study the mixed-mode fracture of plain concrete. In the part of “Damage initiation”, I used QUADS criterion as follows:
*COHESIVE SECTION, elset=cohesion1, material=adhesive1, response=traction separation, THICKNESS=specified
1.0, 1.0,
controls=visco1
*section controls, name=visco1, viscosity=2.5e-2
*MATERIAL, NAME=adhesive1
*ELASTIC, TYPE=TRACTION
3.70e15, 19.70e15, 19.7e15
*density
1.0,
*DAMAGE INITIATION, CRITERION=QUADS
3.70e6, 19.70e6, 19.7e6
In the part of “Damage evolution”, I am trying “type=displacement, softening=tabular.”
Based on mode-I cohesive strength (3.70 MPa) and mode-I energy release rate (107 N/m), I can generate a table to relate “damage” and “effective displacement” for mode-I fracture. At the same time, based on mode-II cohesive strength (19.70 MPa) and mode-II energy release rate (53.5 N/m), I can generate another table to relate “damage” and “effective displacement” for mode-II fracture. I am thinking how I can combine two tables together to take both mode-I and mode-II into consideration. Any suggestion is welcome!
发表于 2011-1-10 21:36:26 | 显示全部楼层 来自 香港
I have the same question for mixed-mode fracture, maybe we can only use UEL or UMAT
GMT+8, 2026-1-2 20:10 , Processed in 0.027598 second(s), 14 queries , Gzip On, MemCache On.
