查看: 47|回复: 1
ICEM error
发表于 2010-9-21 10:35:15 | 显示全部楼层 |阅读模式 来自 广东深圳
Hi, everybody. Here is my problem when i tried to mesh the surface. When i'd finished computing surface mesh using patch dependent method, I checked and found  two curves forming a sharp angle. Knowing that the two curves have no influence on connectivity between surfaces,  I wanted to delete them. By this time, a spread sheet was popped up saying "an internal error has occured: syntax error in expression 'emethod':variable references require preceding$...." What does this mean? Why it happens every time I perform this practice? What can I do then?
Many thanks!
 楼主| 发表于 2010-9-21 10:59:43 | 显示全部楼层 来自 广东深圳
我用ICEM划分面网格后,发现有两条边形成sharp angle,我想把这两条边删除。这时出现“syntax error in expression 'emethod':vaiable references require preceding $” 每回总是这样,为什么呢?
GMT+8, 2024-9-20 15:32 , Processed in 0.026320 second(s), 10 queries , Gzip On, MemCache On.
