查看: 528|回复: 6
[INP文件] 请教base motion的用法
发表于 2010-10-27 10:04:07 | 显示全部楼层 |阅读模式 来自 LAN
base motion按照如下方法用,是否表示对同一个基础进行三向加速度同时加载?如果不对,运用什么关键字可以实现对同一基础进行三向不同加速度载荷加载?谢谢
*MODAL DYNAMIC, CONTINUE = NO
0.01      ,3.0
*Modal Damping
1, 15, 0.02
*base motion, dof=1, amplitude=wave, scale=9800
*base motion, dof=2, amplitude=wave1, scale=9800
*base motion, dof=3, amplitude=wave2, scale=9800
 楼主| 发表于 2010-10-28 21:21:37 | 显示全部楼层 来自 江苏南京
那位高手指点一下吧,急用
 楼主| 发表于 2010-11-4 19:27:32 | 显示全部楼层 来自 江苏南京
难道没有人用这个关键字进行求解?
发表于 2011-7-8 01:23:47 | 显示全部楼层 来自 美国
1st STEP
*FREQUENCY, EIGENSOLVER = LANCZOS, NORMALIZATION = MASS
,1.0       ,500.    ,,,
*BOUNDARY,OP=NEW,BASE NAME=ACCEL_pt1_x
node #,1,1,0.0
*BOUNDARY,OP=NEW,BASE NAME=ACCEL_pt1_y
node #,2,2,0.0
** node # is the node for base excitation input
** Accel_pt1 will be referred to the subsequent step
2nd step
*MODAL DAMPING,MODAL=DIRECT,DEFINITION=FREQUENCY RANGE
xxxxx
xxxx
*BASE MOTION, TYPE = ACCELERATION, LOAD CASE =  1, AMPLITUDE = accel_pt1curve_x,DOF=1,BASE NAME=ACCEL_pt1_x
*BASE MOTION, TYPE = ACCELERATION, LOAD CASE =  1, AMPLITUDE = accel_pt1curve_y,DOF=1,BASE NAME=ACCEL_pt1_y
** accel_pt1curve is the amplitude definition for your base excitation
发表于 2011-7-8 09:05:18 | 显示全部楼层 来自 四川成都
*motion怎么用的
  指定平动速度?
发表于 2011-7-30 10:42:22 | 显示全部楼层 来自 上海
我想施加单点频率的harmonic base motion,使用如下语句,计算的结果确不对,请问Amplitude曲线中的频率的单位是cycle/s还是rad/s啊?
*Amplitude, name=AMP-1
          1.,      0.03099,          19.,      0.03099,          20.,     13.85929,          52.,     2.256129
        900.,     22.56129,        2000.,     4.59661,        2001.,      3.099
** BOUNDARY CONDITIONS
** Name: Disp-BC-1 Type: Symmetry/Antisymmetry/Encastre
*Boundary
SUPP, ZASYMM
** STEP: Step-1
*Step, name=Step-1, perturbation
*Frequency, eigensolver=Lanczos, acoustic coupling=on, normalization=displacement, number interval=1, bias=1.
10, , , , ,
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT, mode list
1, 2, 3,
*End Step
** STEP: Step-2
*Step, name=Step-2, perturbation
*Steady State Dynamics
1., 10000., 20, 1.
*Modal Damping, structural
1, 10, 0.1
*BASE MOTION,DOF=2,AMPLITUDE=Amp-1,SCALE=1
*NODE PRINT,FREQUENCY=1
PU,PTU
发表于 2011-9-8 10:02:14 | 显示全部楼层 来自 辽宁沈阳
stone08 发表于 2011-7-8 01:23
1st STEP
,1.0       ,500.    ,,,
您这个我看明白了点,但是有个小小的疑问:您这个应该是加的x向余弦加速度,幅值是在AMPLITUDE里设置,问题是LOAD CASE=1已经表示为余弦,那么在AMPLITUDE里只要设置幅值大小就可以了吧,那应该选择哪个类型如何设置幅值呢
点评
你怎么看出是加的余弦呢,另外为什么LOAD CASE=1表示为余弦?是不是LOAD CASE=2就是正弦?谢谢  发表于 2013-7-3 10:01
GMT+8, 2024-5-24 01:13 , Processed in 0.060998 second(s), 19 queries , Gzip On, MemCache On.
