查看: 503|回复: 1
[警告错误信息] The parameter hourglass = stiffness on the section controls option is relevant
发表于 2010-12-7 20:20:12 | 显示全部楼层 |阅读模式 来自 北京
The parameter hourglass = stiffness on the section controls option is relevant for these elements: c3d8r, cax4r, cgax4r, cpeg4r, cpe4r, cps4r, m3d4r, m3d9r, s4r5, s4r, s8r5, s9r5, sc6r, sc8r and their hybrid, thermal and pressure counterparts wherever applicable. This warning can be ignored if the feature is applied to these element types only.
Distortion control is not a valid parameter for the *section controls option in abaqus/standard; hence, it will be ignored for the current analysis. It will, however, be stored for any subsequent abaqus/explicit import analysis
In this type of analysis one would normally expect that a density for material geogrid would be defined
这是job监测的信息,在可视化结果里没有任何可以查看的结果
发表于 2010-12-8 10:12:03 | 显示全部楼层 来自 美国
只是由于不支持的原因section controls 中的Distortion control功能省掉了而已,对计算没有任何影响。
GMT+8, 2026-1-7 23:42 , Processed in 0.026495 second(s), 13 queries , Gzip On, MemCache On.
