- 2009-3-11
楼主 |
发表于 2011-1-10 08:01:37
来自 上海
这是整个运行过程的输出信息,烦请大侠帮我分析一下模型哪里出问题了。
谢谢
coil_test (E:/ansoft/temp/Ansoft/)
Maxwell3DDesign1 (EddyCurrent)
[warning] Eddy effect settings may need revisiting due to the recent changes in the design. The default value will be used for the object if the value is not specified. (7:34:06 上午 一月 10, 2011)
[info] Normal completion of simulation on server: Local Machine. (7:35:45 上午 一月 10, 2011)
[info] Parametric Analysis on ParametricSetup1 has been started. (7:35:45 上午 一月 10, 2011)
[info] A variation ($xigma='0.005S_per_m') has been requested on machine Local Machine (7:35:48 上午 一月 10, 2011)
[warning] Eddy effect settings may need revisiting due to the recent changes in the design. The default value will be used for the object if the value is not specified. (7:35:48 上午 一月 10, 2011)
[info] A variation ($xigma='1.11555555555556S_per_m') has been requested on machine Local Machine (7:37:24 上午 一月 10, 2011)
[warning] Eddy effect settings may need revisiting due to the recent changes in the design. The default value will be used for the object if the value is not specified. (7:37:24 上午 一月 10, 2011)
[error] Matrix 'Matrix1': 'Current1' is an invalid source for matrix setup (7:37:24 上午 一月 10, 2011)
[info] A variation ($xigma='2.22611111111111S_per_m') has been requested on machine Local Machine (7:37:24 上午 一月 10, 2011)
[info] A variation ($xigma='3.33666666666667S_per_m') has been requested on machine Local Machine (7:37:25 上午 一月 10, 2011)
[warning] Eddy effect settings may need revisiting due to the recent changes in the design. The default value will be used for the object if the value is not specified. (7:37:25 上午 一月 10, 2011)
[error] Matrix 'Matrix1': 'Current1' is an invalid source for matrix setup (7:37:25 上午 一月 10, 2011)
[info] A variation ($xigma='4.44722222222222S_per_m') has been requested on machine Local Machine (7:37:25 上午 一月 10, 2011)
[info] A variation ($xigma='5.55777777777778S_per_m') has been requested on machine Local Machine (7:37:25 上午 一月 10, 2011)
[info] A variation ($xigma='6.66833333333333S_per_m') has been requested on machine Local Machine (7:37:25 上午 一月 10, 2011)
[info] A variation ($xigma='7.77888888888889S_per_m') has been requested on machine Local Machine (7:37:25 上午 一月 10, 2011)
[info] A variation ($xigma='8.88944444444444S_per_m') has been requested on machine Local Machine (7:37:25 上午 一月 10, 2011)
[info] A variation ($xigma='10S_per_m') has been requested on machine Local Machine (7:37:25 上午 一月 10, 2011)
[error] Matrix 'Matrix1': 'Current1' is an invalid source for matrix setup (7:37:26 上午 一月 10, 2011)
[info] Parametric Analysis is done. (7:37:26 上午 一月 10, 2011) |
