向各位请教,计算时出现warning,说tie那部分出现问题,警告为:For *tie pair (assembly__pickedsurf25-assembly__pickedsurf24), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.不知道tie的时候哪里出了问题?
还有出现这种警告:Slave node 21 instance plate1-1 will not be tied to the master surface assembly__pickedsurf22. The distance from the master surface is greater than the position tolerance value.
qubenben2010 发表于 2011-2-16 10:35
向各位请教,计算时出现warning,说tie那部分出现问题,警告为:For *tie pair (assembly__pickedsurf25-assembly__pickedsurf24), adjusted nodes with very small adjustments were not printed. Specify *preprin ...
qubenben2010 发表于 2011-2-16 10:32
