查看: 73|回复: 2
flotran计算时的错误
发表于 2011-6-10 15:38:11 | 显示全部楼层 |阅读模式 来自 黑龙江哈尔滨
*** ERROR ***                           CP =     425.531   TIME= 15:17:57
Negative or zero temperatures may be avoided by either mesh refinement
or modified inertial relaxation especially if Petrov-Galerkin
formulation is used for the energy equation(FLDA,ENRG,SUPG,T).
*** ERROR ***                           CP =     425.562   TIME= 15:18:18
Negative or zero temperature detected.  This may be caused by a
diverging solution or by an incorrect temperature or property value.
A temperature offset may also be required.  (TOFFST)
  Node = 1546.
在流场和热耦合计算时出现这两个错误怎么解决啊,是什么原因引起的呢?紧急求助!
发表于 2011-6-11 16:30:00 | 显示全部楼层 来自 北京
我也遇到了同样问题,楼主解决了吗?
 楼主| 发表于 2011-6-12 11:06:51 | 显示全部楼层 来自 黑龙江哈尔滨
2# youhaihui
木有,找不到原因!真希望有个牛人来帮一把
GMT+8, 2024-9-20 08:50 , Processed in 0.028679 second(s), 11 queries , Gzip On, MemCache On.
