- 2011-1-1
小弟新学abaqus,遇到了connection to analysis以及system error code 29539的报错,恳请各位高手指教。谢谢。CEA文件已发附件中,请查看,删掉了网格,保留了种子。对于system error code 29539的问题,我看了些论坛的帖子,排除以下可能:杀毒软件(我电脑没装杀毒软件),内存不足(我电脑内存2G),磁盘空间不够(所在磁盘NTFS格式,剩余空间70多G),但还是出现了这问题。迷惑中,求高手指明。
报错信息具体如下:
ERROR in job messaging system: Error in connection to analysis.
Error in job job-gfrp-concrete-1: The executable D:\Simulia\Abaqus\6.9-1\exec\pre.exe aborted with system error code 29539. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Job job-gfrp-concrete-1 aborted due to errors. |
