- 2011-6-22
计算发动机扭转,导入曲轴网格计算的时候出错,求高人指点!灰常感谢!
AutoSHAFT v3.0.3 kernel started... #####################
29-Jun-2011 10:14:40
Initializing started...
Importing crankshaft model started...
Importing crankshaft model done.
Initializing done.
Last step done: NONE
BEGIN Input Check Step
29-Jun-2011 10:14:41
!!! WARNING !!!
AutoSHAFT detected global X-axis as the dominant
crankshaft's axis!
In case of problems during the crankshaft structure
recognition please check definition of the crank-
shaft's rotational axis.
SEVERITY: Critical
NOTE:
For very short crankshafts (e.g. of one-cylinder
engines) it could happen that the dominant axis does
not coincide with the rotational axis. If so, please
consider this warning obsolete.
NUMBER OF INDEPENDENT VOLUMES:
Total number of cavities
0
S U M M A R Y
During crankshaft STL model quality check one or more
warnings/errors have been issued.
In case of any reported error it is not possible to
succesfully continue AutoSHAFT session. It is necessary
to modify the crankshaft model in the corresponding CAD
tool in a way the resulting STL model will comply to the *
AutoSHAFT requirements.
In case of reported warning(s) only, please check the
STL model in AVL/IMPRESS (press 'Show' button in
'AutoSHAFT' dialog). If problems are of minor signifi-
cance, the session can be continued with chances
AutoSHAFT will supply the correct results. Otherwise,
modification of the crankshaft model in the correspon-
ding CAD tool is necessary (as in case of errors).
END Input Check Step
29-Jun-2011 10:14:42
00:00:01
29-Jun-2011 10:14:43
AutoSHAFT kernel exits. ############################
Total time: 00:00:03 |
