- 52
- 2002-9-10
http://www.padtinc.com/support/ansys/tcltk/default.htm
Tcl/Tk in ANSYS
As the engineers at PADT have developed custom applications with the ANSYS software package, they have begun to use the Tcl/Tk command language more and more. In this time, they have learned some important lessons and have gathered some useful resources. This page has been put together for the ANSYS community to help them learn and apply this powerful capability in ANSYS. You can read through the following FAQ or jump right into some tutorials.
What is Tcl/Tk?
Tcl/Tk (pronounced tickle-tee-kay) is a software command language that interfaces with the X11 windowing system. It was developed by John Ousterhout at the University of California, Berkeley in 1989, and has quickly become one of the most popular tools for creating applications with GUI interfaces.
What advantages does Tcl/Tk have over other GUI building tools?
Price. First—and most importantly—Tcl/Tk is free.
Facility. Tcl/Tk is relatively easy to learn in comparison to other software languages (e.g., C++, Fortran, etc.). And since it is an interpreted language, you can immediately see the effects of program modifications without recompiling code.
Flexibility. Tcl/Tk has a wide variety of tools embedded into it which allow you to create entry boxes, canvases, scrollable forms, labels, etc., and allows you to arrange them in an orderly fashion. In addition, you can create your own tools and commands by creating procedures within the programming environment, or by editing the source code and creating your own custom interpreter.
Compatibility. Tcl/Tk is cross-platform compatible. Scripts written for Windows NT will also run on HP-UX, SGI-IRIX, SunOS, and Linux—just to mention a few. Of course, you will have to install Tcl/Tk on each platform that you wish to run on, but since it's free, this is generally not a big problem.
What advantages are there to using Tcl/Tk with ANSYS?
The latest versions of ANSYS have custom Tcl/Tk interpreters compiled into the analysis environment. These custom interpreters have built into them several commands which can be used to send information back and forth between the Tcl/Tk and ANSYS environments. The interpreter can be invoked by simply typing a command; ~tk, ~tcl, or ~eui in the ANSYS input window. Each of these commands have unique functionality which is discussed later on.
Using these tools, you can create an interface with Tcl/Tk to enter parameter values for a design, for example, then use these parameters to issue ANSYS commands or macros to build your model. Or you can create a wizard to guide new users through the process of building a simple model and running an analysis, or perhaps to produce a splash screen listing important phone numbers and email addresses.
You can also combine the functions of Tcl/Tk and ANSYS UIDL (User Interface Design Language). This allows you to create new menu items in the main ANSYS menus which invoke Tcl/Tk scripts, thus enabling a seamless integration of any vertical application that uses ANSYS.
Do I need the complete Tcl/Tk package?
It is not actually required for you install Tcl/Tk in order to use the ANSYS Tcl/Tk interpreter. It will already be installed if you have ANSYS 5.5 or later on your system. However, it is highly recommended for two reasons. First, it is much easier to learn the basic functions of Tcl/Tk by building programs initially outside of the ANSYS analysis environment. Along with the Tcl/Tk core, a help system for Tcl programmers and several sample scripts are included in the basic installation. Second, it is often desirable—even for seasoned users—to build GUIs outside of the ANSYS environment. Besides freeing up a valuable ANSYS license, debugging scripts is a bit simpler to do using the basic Tcl/Tk interpreters.
Which Tk commands are supported in the ANSYS version of Tcl/Tk?
If you ever want to see what Tk commands are currently available in the ANSYS Tcl/Tk interpreters, simply type the following command in the ANSYS input window:
~tk,'puts [info commands]'
All of the available Tk commands will then be listed in the ANSYS output window. This includes ANSYS additions to the tool kit as well as the standard commands.
Where do I get the Tcl/Tk package?
Download the package from the Tcl Developer Exchange. If you are going to do a lot of development work in Tcl/Tk, we recommend that you try out the professional development environment, TclPro. This tool is now available as a free download and will greatly enhance the development experience.
Are there any good Tcl/TK books?
Although the information given here is enough to get you started, you will eventually want to acquire more complete resources. The best books on the subject are Tcl and the Tk ToolKit by John Ousterhout, and Effective Tcl/Tk Programming by Mark Harrison and Michael McLennan. We’ve found both to be invaluable, and both are usually in stock at both Amazon.com and Buy.com.
Are there any good links you can recommend?
There are two very useful sites on the web:
http://www.scriptics.com/
Here you can post questions, view forums, or query the database for information about various workarounds, undocumented commands, etc. Very useful when your stumped.
Tcl/Tk Info Site.
http://www.tcltk.com/
Links and listings of lots of Tcl/Tk information and resources. A good place to start your hunt for scripts and widgets. It also has links to all of the resources on the web, so we won’t repeat them here.
Are there any examples on how to implement Tcl/Tk with ANSYS?
We have a few examples that should get you started on the path to ANSYS customization with Tcl/Tk:
Tcl/Tk Puts a New Face on ANSYS. An article from the Winter 2000 issue of PADT News. http://www.padtinc.com/support/ansys/tcltk/from_news.pdf
My First Splash Screen. A tutorial that steps the user through the creation of a simple dialog box.http://www.padtinc.com/support/ansys/tcltk/splash.htm
Tcl/Tk for ANSYS. A PowerPoint chapter From PADT’s Advanced Customization class(http://www.padtinc.com/support/training/course.asp?c=802). It assumes you know Tcl/Tk already. http://www.padtinc.com/support/ansys/tcltk/advcust/default.htm
Entry Variables and Procs. A response to an XANSYS posting about how to use entry values in procs. http://www.padtinc.com/support/ansys/tcltk/namespace.htm
Also, the GUI subdirectory of your ANSYS56 directory contains the Tcl/Tk scripts that ANSYS uses for the contact wizard, the Mechanical Tool Bar, and other interfaces. These are good intermediate and advanced examples of using Tcl/Tk with ANSYS.
[Warning: Don’t work with these files directly! These files are needed in their original form for ANSYS to work correctly. Make a copy them in a safe directory away from the ANSYS directory, and then work with the copies.] |
