- 2004-3-26
NOTE : For 2D axisymmetric problems the following
masses are reported per radian.
For 2D plain strain/stress problems the
masses are reported per unit thickness.
summary of mass
part id = 1 mass = 0.10981511E+04 rigid body
part id = 2 mass = -0.52733850E+03
part id = 3 mass = 0.27012367E+01 mass in rigid body = 0.89856006E-01
part id = 4 mass = 0.12000739E+04 rigid body
t o t a l m a s s = 0.17734978E+04
x-coordinate of mass center = 0.10942566E+01
y-coordinate of mass center = 0.40298801E-05
z-coordinate of mass center = 0.73167264E+00
slave surface of interface # 1 type= 13
surface timestep= 0.629E-06 current minimum= 0.629E-06
The LS-DYNA time step size should not exceed 0.629E-06
to avoid contact instabilities. If the step size is
bigger then scale the penalty of the offending surface.
0 t 0.0000E+00 dt 0.00E+00 flush i/o buffers
100 smallest timesteps
element timestep
shell 20933 0.30928E-05
shell 20943 0.30928E-05
*** Warning Initialization
single surface interface # = 1
penetrating node # = 4779
segment # = 4589
penetration = -0.1000073E-02
s,t = -0.9997566E+00 -0.9189054E-04
penetrated segment nodes:
4716 4719 4720 4715
original coordinates of slave node= 4779
x-coordinate = 0.122382104E+01
y-coordinate =-0.505997062E+00
z-coordinate = 0.732106447E+00
modified coordinates of slave node= 4779
x-coordinate = 0.122282100E+01
penetrating node # = 4788
segment # = 4593
s,t = 0.9999999E+00 -0.2483528E-05
4731 4706 4707 4732
original coordinates of slave node= 4788
y-coordinate =-0.386000007E+00
z-coordinate = 0.732107520E+00
modified coordinates of slave node= 4788
penetrating node # = 4789
segment # = 4584
penetration = -0.9999536E-03
s,t = -0.6192006E+00 0.8666271E-01
4717 4718 4719 4716
original coordinates of slave node= 4789
y-coordinate =-0.501430392E+00
z-coordinate = 0.709147513E+00
modified coordinates of slave node= 4789
x-coordinate = 0.122281909E+01
penetrating node # = 4790
segment # = 4579
s,t = 0.4646854E+00 0.4646421E+00
4698 4700 4718 4717
original coordinates of slave node= 4790
y-coordinate =-0.488423765E+00
z-coordinate = 0.689683259E+00
modified coordinates of slave node= 4790
z-coordinate = 0.689683259E+00 |
