- 2003-7-17
以下是输出文档(piston1p1_0tfullchange_e.out.txt)中的内容,我能看出节点数来,请问哪个是单元数阿,是不是那个“NUMBER OF NON-ZERO MATRIX ELEMENTS . . . .(NZC) = 135102”阿?赫赫,找了半天也没找到:(
文档内容:
S T O R A G E R E Q U I R E M E N T
MAXIMUM TOTAL STORAGE AVAILABLE (MTOT) = 64000000
REQUESTED STORAGE FOR IN-CORE SOLUTION......(IOPTIM=3)= 9351871
REQUESTED STORAGE FOR K-MATRIX IN-CORE ONLY (IOPTIM=2)= 3647552
S O L U T I O N B Y S P A R S E S O L V E R
TOTAL SYSTEM DATA
NUMBER OF NODES. . . . . . . . . . . . . (NUMNP) = 18395
NUMBER OF EQUATIONS. . . . . . . . . . . .(NEQ) = 18395
NUMBER OF EQUATIONS WITHOUT RADIOSITY. . .(NEQI) = 18395
MAXIMUM TOTAL STORAGE AVAILABLE. . . . . (MTOT) = 64000000
INCORE SOLUTION FLAG . . . . . . . . . .(IOPTIM) = 3
TOTAL NUMBER OF BLOCKS . . . . . . . . .(NBLOCK) = 1
NUMBER OF RADIOSITY BLOCKS . . . . . . .(NBLOCR) = 0
NUMBER OF PROCESSORS USED. . . . . . . .(NPROTT) = 1
ESTIMATED MEMORY TO BE TAKEN . . . . . .(MESTIM) = 9351871
ACTUAL MEMORY STORAGE TAKEN. . . . . . . (NZMAX) = 9351867
* <<<<< ADINA-T SPARSE SOLVER INFORMATION >>>>> *
* NUMBER OF MATRIX ELEMENTS..........................= 2859125 *
* STORAGE USED BY THE SOLVER (IN WORDS)..............= 6138976 *
* TOTAL STORAGE USED BY THE PROGRAM (IN WORDS).......= 70138976 *
* << IN-CORE SOLUTION >> *
STEP NUMBER = 1 ( TIME STEP= 0.10000000E+01, SOLUTION TIME = 0.10000000E+01 )
LARGEST DIAGONAL ELEMENT OF THE FACTORIZED MATRIX= 0.64016E+01, EQUATION= 15938
SMALLEST DIAGONAL ELEMENT OF THE FACTORIZED MATRIX= 0.92716E-01, EQUATION= 127
NO EQUILIBRIUM ITERATIONS IN THIS TIME STEP
CONDUCTIVITY REFORMED FOR THIS TIME STEP
NODAL RESULTS ARE WRITTEN TO THE PORTHOLE AT TIME= 0.10000000E+01, TIME STEP=
ELEMENT RESULTS ARE WRITTEN TO THE PORTHOLE AT TIME= 0.10000000E+01, TIME STEP=
PREVIOUSLY WRITTEN RESTART DATA IS OVERWRITTEN, TIME= 0.1000000000000E+01
1PROGRAM ADINA-T - VERSION 8.0.7 (build 04.05.2003) *** piston1p1_0tfull ***
LICENSED FROM A D I N A R & D INC.
S O L U T I O N T I M E L O G (IN SECONDS)
FOR PROBLEM
INPUT PHASE . . . . . . . . . . . . . . . . . . 6.07
ASSEMBLAGE OF LINEAR CONDUCTIVITY, HEAT
CAPACITY MATRICES . . . . . . . . . . 1.06
ASSEMBLAGE OF HEAT FLOW VECTORS . . . . . . . . 0.34
FREQUENCY ANALYSIS . . . . . . . . . . . . . . 0.00
TRIANGULARIZATION OF LINEAR (EFFECTIVE)
CONDUCTIVITY MATRIX . . . . . . . . . . . 1.93
STEP-BY-STEP SOLUTION ( 1 TIME STEPS )
CALCULATION OF EFFECTIVE HEAT FLOW VECTORS 0.00
UPDATING EFFECTIVE CONDUCTIVITY MATRICES AND
HEAT FLOW VECTORS FOR NONLINEARITIES . . 0.00
SOLUTION OF EQUATIONS. . . . . . . . . . . 0.20
EQUILIBRIUM ITERATIONS . . . . . . . . . . 0.00
CALCULATION AND PRINTING OF RESULTS. . . . 1.02
STEP-BY-STEP TOTAL . 1.22
T O T A L S O L U T I O N T I M E (SECONDS) 10.68 |
