- 12
- 2004-7-21
5.3.7 Assign Constitutive Models and Properties设定基本模型和参数
A constitutive model is associated with a specific region of the grid through the MODEL command. The mechanical constitutive models available in are discussed in Appendix G. The following keywords are available to assign the appropriate model.
通过MODEL命令设定一个特定网格区域的基本模型,用在FLAC3D的物理基本模型将在附录G中讨论,下面的关键字可以用来设置适当的模型。
Mechanical Model物理模型
anisotropic transversely isotropic elastic model
各向异性 横切等方向弹性模型
cam-clay Cam-clay model
凯穆粘土 凯穆-粘土模型
drucker Drucker-Prager plasticity
德普卢克 德普-卢克塑性模型
elastic isotropic elastic model
弹性 各项同性弹性模型
finn dynamic pore-pressure generation model (available only for dynamic option, see Appendix K)
芬兰 动态孔隙压力生成模型(仅适用于动态选项,见附录K)
mohr Mohr-Coulomb plasticity model
摩尔 摩尔-库仑塑性模型
null null model (i.e., no material)
空模型(即没有材料)
orthotropic orthotropic elastic model
ssoftening strain-hardening/softening plasticity model
应力-硬化/软化塑性模型
subiquitous bilinear strain-hardening / softening ubiquitous-joint model
双线性应力-硬化/软化全节理(裂隙)模型
ubiquitous ubiquitous-joint model
到处存在的 全节理模型
Fluid-Flow Model (see Appendix M)流体模型(见附录M)
Fl_isotropic isotropic fluid flow 均质流体
Fl_null null zone for fluid flow 空单元流体
Creep Model (available only for creep model option, see Appendix I)
蠕变模型(仅在蠕变模型选项中可用,见附录I)
cwipp crushed-salt constitutive model
变形刺激构成模型
power two-component power law
两分量力量规则
pwipp viscoplastic model
粘塑性模型
viscous classical viscoelastic model
经典粘塑性模型
wipp WIPP reference creep formulation
WIPP参考蠕变方程
Thermal Model (available only for thermal model option, see Appendix J)
th_isotropic isotropic thermal conductivity均质热导体
th_null null zone for heat conduction 热导空单元
Properties are assigned for each model through the PROPERTY command. For the strain-hardening/softening model, properties can depend upon accumulated plastic strain as defined through the TABLE command. Fluid flow properties (fluid bulk modulus or Biot’s modulus) are prescribed with the INITIAL command. Mass densities for the material and the fluid are also prescribed with the INITIAL command.
通过PROPERTY命令来设置各个模型的参数。对于应力-硬化/软化模型,参数依赖于通过TABLE命令定义的积聚的塑性应力。 |
