- 73
- 2003-1-6
发表于 2006-4-7 15:02:03
来自 美国
Re:一个热分析结果,有点疑问,请指点
I don't feel confused.
Let's make clear one thing. Is this transient or steady-state problem?
My understanding is that at the beginning it is transient and as time goes on it will becomes steady-state which means at each point the temperature is not changing any more and different points may have different temperatures. If in this case, air is the only way to carry away the heat, I think when the convection coefficient goes small, the temperature will keep rising. We should have no doubt about this point. Since heat has no where to go and it will just accumulate. My original thought was that we have two types of boundary condition in this case, one is convection which is Neumann and one is temperature which is Dirichlet, for instance, the fin touches something containing coolant. If convection is gone, heat can only dissipate toward the Dirichlet boundary. Do you agree with this?
By the way you could say L_N boundary become adiabatic as alpha->0. But you cannot say L_D boundary become adiabatic because I just specify the temperature and I don't specify any flux. This is agaist intuition. But it is correct.
Luckily I passed the qualifying exam and was not failed by this problem.
Anyway it is such a pleasure to have a discussion with you.
iomega wrote:
If you want , I can bet 100 bucks.
Let us put in this way: assume the air convection is elimated, then where the heat generated from the chip will go? There will be no thermal ground to the system (if assume no heat radiation). Just like you touch a high voltage electrical cable, but you wear a insulating shoe, there will be no electrical current flow in your body to the ground. Therefore, everywhere in your body has the same voltage potential. Same thing for the heat conduction.
Remember, temperature gradient means you have heat flow in the structure. if the air convection disappears, where the heat flow from 散热片 to?
Also your example prove what I said is right -> "There will force the heat to transfer along the cooling fin and there will be more obvious temperature gradient".
You assume the cooling fin is the 散热片, right? the whole 散热片 is in the air, since air convection is zero, 散热片 is no longer a coolin fin.
You only consider that the L_N boundary (air convection) adiabatic, but for this specific problem, if alf->0, both L_N and L_D boudary become adiabatic.
My dear friend, this could be a typical qualify exam problem and I see many people were confused before.
If you look at the Ph.D thesis from MIT, Stanford, berkeley students, at least five people's research structures were based this type of so-called fin problem. |
