- 2005-11-20
Date: 05/19/2006 Time: 13:08:36
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version: 970 Date: 07/30/2004 |
| Revision: 5434 Time: 15:01:01 |
| Features enabled in this version: |
| ANSYS Database format |
| Shared Memory Parallel |
| Licensed to: |
| Platform : |
| OS Level : WINDOWS XP |
| Hostname : neu_kxw |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
Input file: E:\zcl\111.k
The native file format : 32-bit small endian
Memory size from command line: 350000000
expanding memory to 350000000
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2003 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 770212
expanding memory to 1520424
expanding memory to 2407440
expanding memory to 5810394
expanding memory to 5840394
expanding memory to 5900394
expanding memory to 5931412
expanding memory to 5992912
*** Error line number 333542 contains improperly formatted data
(This is line# 333542 of file
E:\zcl\111.k)
--------------------------------------------------------------line# 333542 -----
*** Error reading *DATABASE_BINARY_D3DUMP
expanding memory to 7644630
expanding memory to 7791466
expanding memory to 7938302
expanding memory to 8085138
expanding memory to 11443092
expanding memory to 11589928
*** Error input data failed with: 1 errors
E r r o r t e r m i n a t i o n
Memory required for explicit solution : 0
Additional dynamically allocated memory: 0
Total: 0
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 0.0000E+00 0.00 0.0000E+00 0.00
Element processing ... 0.0000E+00 0.00 0.0000E+00 0.00
Binary databases ..... 0.0000E+00 0.00 0.0000E+00 0.00
ASCII database ....... 0.0000E+00 0.00 0.0000E+00 0.00
Contact algorithm .... 0.0000E+00 0.00 0.0000E+00 0.00
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 0.0000E+00 0.00 0.0000E+00 0.00
Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 0 seconds ( 0 hours 0 minutes 0 seconds)
CPU time per zone cycle = 0 nanoseconds
Clock time per zone cycle= 0 nanoseconds
Number of CPU's 0
NLQ used/max 96/ 96
Start time 05/19/2006 13:08:36
End time 05/19/2006 13:08:47
Elapsed time 11 seconds ( 0 hours 0 minutes 11 seconds)
我想用刚性的辊子带动弹性的模具轧制,为什么会出现这样的错误啊??应该怎么修改,谢谢了,我真的着急啊! |
