- 14
- 2005-6-7
;file
;Int_force_setout.dat
;Used for FLAC2D only
; Get the normal froce and shear shear of interfaces.Set out the normal and
; shear force by plot.In the plot , X-axes is the X-cordinate of the ;
interface and Y-axes is the absolute value of the force.
;-------------- written by tg0215 on 2006-9-4 -----------------------------
set echo off
cal int.fin
set echo on
; example model
g 10 11
m e
prop dens 2000 sh 1e8 bu 2e8
m n j=6
ini x add 2.5 y add -0.9 j=7,12
int 4 aside from 1,6 to 11,6 bside from 1,7 to 11,7
int 4 kn 5e8 ks 2.5e8 fric 10
set grav 10,5 large
fix x y j=1
step 1000
def save_data
ip=int_pnt
loop while ip # 0
id_int=imem(ip+$kicid)
A_side_pointer=imem(ip+$kicapt)
B_side_pointer=imem(ip+$kicbpt)
n=1
loop while A_side_pointer # 0
jj=imem(A_side_pointer+$kidj)
ii=imem(A_side_pointer+$kidi)
xtable(id_int,n)=x(ii,jj)
xtable(id_int+10,n)=x(ii,jj)
ytable(id_int,n)=abs(fmem(A_side_pointer+$kidfn))
ytable(id_int+10,n)=abs(fmem(A_side_pointer+$kidfs))
A_side_pointer=imem(A_side_pointer)
n=n+1
endloop
ip=imem(ip)
endloop
end
save_data
def set_out
ip=int_pnt
loop while ip # 0
ppp=id_int+10
command
pl hold table id_int both
pl hold table ppp both
endcommand
ip=imem(ip)
endloop
end
set_out |
