- 2006-10-11
诚恳希望得到各位的点拨,以达对flac结构化的认识,为感!!双排桩,中间以连梁(beam单元模拟)相连
new
plot sk
;建立土体模型
gen zone brick size 30 11 30
group clay
mod mohr range group clay
pro bulk 5e6 shear 1.6e6 cohesion 15000 &
friction 8 dilation 0. tension 0. range group clay
;设置边界条件和初始应力
fix x range x -.1 .1
fix x range x 29.9 30.1
fix y range y -.1 .1
fix y range y 10.9 11.1
fix z range z -0.1 0.1
ini szz -369000 grad 0 0 12300 range z 0 30
ini sxx -158130 grad 0 0 5271 range z 0 30
ini syy -158130 grad 0 0 5271 range z 0 30
;设置结构单元
sel pile id 1 begin 10 0 30 end 10 0 10 nseg 17
sel pile id 1 begin 11 0 30 end 11 0 10 nseg 17
sel pile id 1 begin 10 2.5 30 end 10 2.5 10 nseg 17
sel pile id 1 begin 11 2.5 30 end 11 2.5 10 nseg 17
sel pile id 1 begin 10 5 30 end 10 5 10 nseg 17
sel pile id 1 begin 11 5 30 end 11 5 10 nseg 17
sel pile id 1 begin 10 7.5 30 end 10 7.5 10 nseg 17
sel pile id 1 begin 11 7.5 30 end 11 7.5 10 nseg 17
sel pile id 1 begin 10 10 30 end 10 10 10 nseg 17
sel pile id 1 begin 11 10 30 end 11 10 10 nseg 17
sel nod id 501 10.5 0 30
sel nod id 502 10.5 2.5 30
sel nod id 503 10.5 5 30
sel nod id 504 10.5 7.5 30
sel nod id 505 10.5 10 30
sel nod id 601 10 1.25 30
sel nod id 602 10 3.75 30
sel nod id 603 10 6.25 30
sel nod id 604 10 8.75 30
sel nod id 701 11 1.25 30
sel nod id 702 11 3.75 30
sel nod id 703 11 6.25 30
sel nod id 704 11 8.75 30
def set_beam
loop ii (1,5)
iid1=1+36*(ii-1);节点号
iid2=500+ii
iid3=19+36*(ii-1)
command
sel beamsel id 2 nodes iid1 iid2 ;刚性梁
sel beamsel id 2 nodes iid2 iid3
endcommand
endloop
end
set_beam
def qianliang
loop ii (1,4)
iid1=1+36*(ii-1) ;节点号
iid2=600+ii
iid3=37+36*(ii-1);节点号
command
sel beamsel id 3 nodes iid1 iid2 ;前梁
sel beamsel id 3 nodes iid2 iid3
endcommand
endloop
end
qianliang
def houliang
loop ii (1,4)
iid1=19+36*(ii-1);节点号
iid2=700+ii
iid3=55+36*(ii-1);节点号
command
sel beamsel id 3 nodes iid1 iid2 ;后梁
endcommand
endloop
end
houliang
sel pile id = 1 prop emod 3.0e10 nu 0.16 xcarea 0.785 & ;半径设置不合理???
xciy 0.049 xciz 0.049 xcj 0.092 &
per 3.14 &
cs_sk 0.11e9 cs_scoh 1e4 cs_sfric 13.46 &
cs_nk 0.67e9 cs_ncoh 0.0 cs_nfric 0.0 cs_ngap off
sel beam id = 2 prop emod 3.0e10 nu 0.16 xcarea 0.785 &
sel beam id = 3 prop emod 2.2e11 nu 0.13 xcarea 0.196 &
xciy 2e-4 xciz 2e-4 xcj 4e-4 &
ydir 1 0 0
ini dens 2000 range group clay
set gravity 0 0 -10.0
hist unbal
solve ratio 1.e-6
solve
;开挖模拟
ini xdis 0 ydis 0 zdis 0
model null range x 0 10 y 0 11 z 20 30
step 100000
save liang.sav
[ 本帖最后由 liangqiumin 于 2007-2-16 20:10 编辑 ] |
