楼上的,谢谢你在建模中提醒,我没用多长时间,所以不太熟悉,我的命令流是这样的:
/FILNAME,CONTINUOUS CASTING
/TITLE,CONTINUOUS CASTING
/PREP7
ET,1,PLANE55
et,2,surf151
KEYOPT,2,4,1
KEYOPT,2,5,1
KEYOPT,2,6,0
KEYOPT,2,7,1
KEYOPT,2,8,2
KEYOPT,2,9,1
r,2,1,5.67e-8
mptemp,1,211,800,911,1392
mpdata,c,1,,482.166587,622.093856,648.463851,762.733828
mpdata,kxx,1,,44.605510,31.300000,28.792510,17.926720
mpdata,enth,1,,0,7.5e9,9.6e9,1.1e10
mpdata,dens,1,,7779.765800,7637.110000,7610.225800,7493.727600
MP,EMIS,2,0.8
RECTNG,0,0.75,0,0.125
LSEL,S,,,1
LESIZE,ALL,,,50,0.2
LSEL,S,,,3
LESIZE,ALL,,,50,5
LSEL,S,,,2
LESIZE,ALL,,,20,0.2
LSEL,S,,,4
LESIZE,ALL,,,20,5
AMESH,1
TYPE,2
REAL,2
MAT,2
*GET,NN,NODE,,num,max
LSEL,S,,,2,3
NSLL,S,1
N,NN+1,0,0.2,0
ESURF,NN+1
ALLSEL
SAVE,124v925,db
SAVE
/SOLU
ANTYPE,TRANS
TIMINT,ON
bfunif,temp,1550
!结晶器-----------------------------------------------------------
*set,result1,0
*set,result11,0
*set,result2,0
*set,result21,0
*set,a,-6614.7
*set,b,10234
*set,c,-5811.9
*set,d,2300.9
*set,e,-6814
*set,f,10592
*set,g,-60503
*set,h,2023.1
*DO,i,1,42
!宽面
*set,a1,a*i*i*i/3600/60
*set,a2,b*i*i/3600+c*i/60
*set,result1,a1+a2+d
*set,result11,(result1+result11)
LSEL,S,,,3
NSLL,S,1
SF,ALL,HFLUX,result11
!窄面
*set,m,i
*set,a3,e*m*m*m/3600/60
*set,a4,f*m*m/3600+g*m/60
*set,result2,a3+a4+h
*set,result21,(result2+result21)
LSEL,a,,,2
NSLL,a,1
SF,ALL,HFLUX,result21
TIME,i
autos,1
KBC,1
NSUBST,2
ALLSEL,ALL
LSWRITE,i
*ENDDO
OUTRES,ALL,ALL
LSSOLVE,1,42,1
!二冷区---------------------------------------------------------------------------------
!zhc198111@163.com
antype,4,rest
ESEL,s,TYPE,,2
LSEL,s,,,2
NSLL,s,1
LSEL,a,,,3
NSLL,a,1
SF,all,conv,800,27
TIMINT,ON
TIME,300
deltim,15,15,30
autots,on
KBC,1
NSUBST,2
OUTRES,ALL,ALL
SOLVE
!辐射---------------------------------------------------------------------------------------
TIME,1026
deltim,15,15,30
TOFFST,273
AUTOTS,ON
ALLSEL
d,nn+1,temp,27
KBC,1
NSUBST,2
OUTRES,all,ALL
outpr,nsol,last
SOLVE
finish
/POST1
/PLOPTS,INFO,ON
PLNSOL,TEMP
FINISH
你说的
"sf,all,hflux,!施加热流密度
esel,s,mat,,2
sfe,all,1,conv,1,!施加对流面荷载
是直接加完热流密度,就加对流了,但我的必须是,先求解"结晶器"(边界是热流密度),然后在求解"二冷"(边界是对流),不知道怎么写?楼上能否在指点一下.小弟先谢了! |
