- 2006-8-30
在建好模型划分网格之后,创建流体物理环境时是否先要用asel命令选中流体区,然后设置流体边界条件?
流体固体的材料属性都是在创建物理环境时才设置吗?流体没有材料属性,难道不需要定义?
流体固体材料属性并没有定义也可以用aatt设置网格单元属性?
只要你知道任何一个问题的答案,请你告诉我,十分感谢!
/Batch,list
/prep7
/sho,gasket,grph
shpp,off
ET,1,141 ! Fluid - static mesh
ET,2,56, ! Hyperelastic element
yent = 0.0 ! Y coordinate of the entrance to the pipe
dyen = 1.0 ! Undeformed geometry flow entrance length
ysf1 = yent+dyen ! Y coordinate of entrance to the morphing fluid region
dsf1 = 0.5 ! Thickness of upstream
ygas = ysf1+dsf1 ! Y coordinate of the bottom of the gasket
dg = 0.02 ! Thickness of the gasket
dg2=dg/2.
ytg = ygas+dg ! Y coordinate of the initial top of the gasket
dsf2 = 0.5 ! Thickness of downstream region
ysf2 = ytg + dsf2! Y of Top of the downstream morphing fluids region
dyex = 6.0 ! Exit fluid length
x = 0. ! Location of the axisymmetric Centerline
dgasr =.20 ! Initial span of gasket
piper = 0.3 ! Radius of the pipe
xrgap = piper-dgasr!! radius of completely unobtructed flow passage
!!! Create geometry
rect,xrgap,piper,ygas,ytg ! A1:Gasket (keypoints 1-4)
rect,x,piper,ysf1,ysf2 ! A2: Morphing fluid region
rect,x,piper,yent,ysf1 ! A3: Fluid region with static mesh
rect,x,piper,ysf2,ysf2+dyex ! A4: Fluid region with static mesh
aovlap,all
k,22,xrgap+dg2,ygas+dg2
rarc = dg2*1.1
larc,1,4,22,rarc
al,6,4
adelete,7
al,6,3,22,7,8,5,21,1
!!Mesh Division information
ngap = 10 ! Number elements across the gap
ngas = 10 ! Number of elements along the gasket
rgas = -2 ! Spacing ratio along gasket
nflu = ngap+ngas ! Number of elements across the fluid region
raflu = -3 ! Space fluid elements near the walls and center
nenty =8 ! Elements along flow - entrance
raent =5 ! Size ratio in the inlet region
nfl1 = 20 ! Elements along flow - first morph.fluid.
nthgas = 4 ! Elements in the gasket
nfl2 = 3 ! Elements along flow - second morph.fluid.
next = 30 ! Elements along flow - exit region
rext = 6 ! Size ratio in flow direction of outlet
rafls = 12 ! Initial element spacing ratio - morph.fluid
lesize,1,,,ngas,rgas
lesize,3,,,ngas,rgas
nfl11= nfl1*2+9
lsel,s,,,2,4,2 ! (Modify lesize of line 8 if changing gasket mesh)
lesize,all,,,nthgas
alls
lesize,5,,,nflu,raflu
lesize,7,,,nflu,raflu
lesize,9,,,nflu,raflu
lesize,15,,,nflu,raflu
lesize,18,,,nenty,1./raent
lesize,17,,,nenty,1./raent
lesize,21,,,nfl1,rafls
lesize,8,,,nfl11,-1./(rafls+3)
lesize,22,,,nfl1,rafls
lesize,19,,,next,rext
lesize,20,,,next,rext
!!! AATT,MAT,REAL,TYPE - Set the attributes for the areas
asel,s,,,1,2
aatt,2,2,2 ! Gasket (material 2) 材料并没有定义也可以用aatt设置网格单元属性?
asel,s,,,3
cm,area2,area
alist ! List area selected for further morphing
asel,a,,,5,6
aatt,1,1,1 ! Fluid area (material 1)
alls
eshape,2
asel,u,,,2,3
amesh,all
eshape,0
asel,s,,,2,3
amesh,all
!-----------------在这之前都是在创建模型和划分网格吗?
!!!!! Create element plot and write to the file gasket.grph
asel,s,,,1,3
esla,s
/Title, Initial mesh for gasket and neighborhood 此处定义分析标题干什么
eplot
/ZOOM,1,RECT,0.3,-0.6,0.4,-0.5
alls
!!!!! 2. Create Physics Environment for the Fluid 创建流体物理环境前不需要先选择流体区域吗?
et,1,141
et,2,0 ! Gasket becomes the Null Element
vin=3.5e-1 ! Inlet water velocity (meters/second)
!! CFD Solution Control
flda,solu,flow,1
flda,solu,turb,1
flda,iter,exec,400
flda,outp,sumf,10
!! CFD Property Information
flda,prot,dens,constant
flda,prot,visc,constant
flda,nomi,dens,1000. ! 1000 kg/m3 for density - water
flda,nomi,visc,4.6E-4 ! 4.6E-4 kg-s/m (viscosity of water)
flda,conv,pres,1.E-8 ! Tighten pressure equation convergence
!! CFD Boundary Conditions (Applied to Solid Model)
lsel,s,,,8,17,9
lsel,a,,,20
dl,all,,vx,0.,1 ! Centerline symmetry
lsel,s,,,9
dl,all,,vx,0.,1
dl,all,,vy,vin,1 ! Inlet Condition
lsel,s,,,2
lsel,a,,,18,19
lsel,a,,,21,22
dl,all,,vx,0.,1 ! Outer Wall
dl,all,,vy,0.,1
lsel,s,,,1,3,2
lsel,a,,,6
dl,all,,vx,0.,1 ! Gasket
dl,all,,vy,0.,1
lsel,s,,,15
dl,15,,pres,0.,1 ! Outlet pressure condition
!!! create named component of nodes at the bottom of gasket
lsel,s,,,1
nsll,,1
cm,gasket,node
nlist ! List initial nodal positions of the bottom of the gasket
/com, +++++++++ STARTING gasket coordinates --------
alls
/title,Fluid Analysis 此处又定义分析标题干什么
physics,write,fluid,fluid
!!!!! 3. Create Physics Environment for the Structure
physics,clear
et,1,0 ! The Null element for the fluid region
et,2,56 ! Gasket element - material 2
mp,ex,2,2.82E+6 ! Young's modulus for rubber 在此处定义材料属性?
mp,nuxy,2,0.49967 ! Poisson's ratio for the rubber
tb,mooney,2
tbdata,1,0.293E+6 ! Mooney-Rivlin Constants
tbdata,2,0.177E+6 ! " " "
lsel,s,,,2
nsll,,1
d,all,ux,0.
d,all,uy,0. ! Fix the end of the gasket
alls
/title,structural analysis
finish
/solu
antype,static
nlgeom,on
cnvtol,f,,,,-1
physics,write,struc,struc
physics,clear
save
!!!!! 4. Fluid-Structure Interaction Loop
loop=25 ! Maximum allowed number of loops
toler=0.005 ! Convergence tolerance for maximum displacement
*dim,dismax,array,loop ! Define array of maximum displacement values
*dim,strcri,array,loop ! Define array of convergence values
*dim,index,array,loop
*do,i,1,loop ! Execute fluid -> structure solutions
/solu
physics,read,fluid ! Read in fluid environment
*if,i,ne,1,then
flda,iter,exec,100 ! Execute 100 global iterations for
*endif ! each new geometry
solve ! FLOTRAN solution
fini
! end of fluid portion
physics,read,struc ! Read in structures environment
/assign,esave,struc,esav ! Files for restarting nonlinear structure
/assign,emat,struc,emat
*if,i,gt,1,then ! Structural restart loop
parsave,all ! Save parameters for convergence check
resume ! Resume DB - to return original node positions
parresume ! Resume parameters needed for convergence check
/prep7
antype,stat,rest
fini
*endif
/solu
solc,off
lsel,s,,,1,3,2 ! Select proper lines to apply fluid pressures
lsel,a,,,6 ! to the entire gasket surface
nsll,,1
esel,s,type,,2
ldread,pres,last,,,,,rfl ! Apply pressure surface load from Flotran
alls
rescontrol,,none ! Do not use multiframe restart for nonlinear
solve
*if,i,eq,1,then
save ! save original node locations at the first run
*endif
fini
/post1
cmsel,s,gasket
nsort,u,sum,1,1
*get,dismax(i),sort,0,max ! Get the maximum displacement value
strcri(i)=toler*dismax(i)
alls
fini
/prep7
mkey=2 ! Select level of mesh morphing for fluid
damorph,area2, ,mkey ! Perform morphing of "morphing fluid"
!!!!! Create element plot and write it in file gasket.grph
fini
/prep7
et,1,42
asel,s,,,1,3
esla,s
/Title, EPLOT after DAMORPH,area2, ,%mkey% step number %i%
eplot
alls
cmsel,s,gasket
nlist ! List updated coordinates of bottom of gasket for comparison
/com, +++++++++ UPDATED gasket coordinates --------
alls
fini
/assign,esav
/assign,emat
!!!! Checking convergence criteria
imax= i
index(i)=i
*if,i,gt,1,then
strcri(i)=abs(dismax(i)-dismax(i-1))-toler*dismax(i-1)
*if,strcri(i),le,0,then
strcri(i)=0
*exit ! Stop looping if convergence is reached
*endif
*endif
*enddo
!!!!! End of the Computational loop
save ! Nodal coordinates of deformed geometry are saved
!!!!! Convergence printout
*vwrite
(/'Loop No. Max.Displacement Struct.Convergence')
/nopr
*vlen,imax
*vwrite,index(1),dismax(1),strcri(1)
(f7.0,2e17.4)
finish
!!!!! Postprocessing of the results
!!! 1. Flotran results.
physics,read,fluid
/post1
set,last
/Title, Flotran: Streamlines Near Gasket
plnsol,strm
/Title, Flotran: Pressure Contours
plnsol,pres
fini
!!! 2. Structural results.
physics,read,struc
/post1
set,last
upcoord,-1 ! Return original node positions changed by morphing
/Title, Structural results: von Mises Stress
plnsol,s,eqv,1,1
fini
!/exit,nosave |
