- 2006-4-25
发表于 2008-1-24 03:41:23
来自 加拿大
about the internal parameters in the model
The TWAIT is set to be 20, if I did not remember it wrong, you can change it as the internal varible in the stateflow explore.
As to the tick, you can not change it, cus it is the default value in the matlab system, as a time counting step.
If you really want to change this number, you can set your own timer outside this subsystem and make it as a event input and then use it.
Hope it can helps!
