查看: 387|回复: 8
有没有ANSYS温度应力分析的例题啊?
发表于 2008-4-8 08:59:30 | 显示全部楼层 |阅读模式 来自 重庆沙坪坝区
菜鸟求救~~~~~~~~~~~~~~~~~~~~~~~
发表于 2008-4-12 09:32:05 | 显示全部楼层 来自 山东威海
/filname,Q235
/title,Q235  WELDING 2-D FEA
/units,si
/prep7
et,1,plane55
et,2,surf151
keyopt,2,8,4
mptemp,1,20,250,500,750,1000,1500
mptemp,7,1700,2500
mpdata,kxx,1,1,50,47,40,27,30,35
mpdata,kxx,1,7,140,142
mpdata,dens,1,1,7820,7700,7610,7550,7490,7350
mpdata,dens,1,7,7300,7090
mpdata,c,1,1,460,480,530,675,670,660
mpdata,c,1,7,780,820
mpdata,prxy,1,1,0.28,0.29,0.31,0.35,0.4,0.45
mpdata,prxy,1,7,0.48,0.5
mpdata,alpx,1,1,1.10e-5,1.22e-5,1.39e-5,1.48e-5,1.34e-5,1.33e-5
mpdata,alpx,1,7,1.32e-5,1.31e-5
mpdata,ex,1,1,2.05e11,1.87e11,1.50e11,7.0e10,2.0e10,1.9e10
mpdata,ex,1,7,1.8e10,1.2e10
tb,biso,1,6,2
tbtemp,20
tbdata,,2.20e8,2.05e10
tbtemp,500
tbdata,,1.3e8,1.50e10
tbtemp,750
tbdata,,4.0e7,7.0e9
tbtemp,1000
tbdata,,2.50e7,2.0e9,
tbtemp,1700
tbdata,,1.0e6,1.8e9
tbtemp,2500
tbdata,,1.0e5,1.2e9,
pi=3.1415926
I=100 !焊接电流
U=23 !焊接电弧电压
effcient=0.85 !焊接热效率η
r=0.005 !电弧有效加热半径
Qm=3*I*U*effcient/(pi*r**2) !最大热流高斯密度
kk=0.85 !能量集中系数
Qmax=Qm*kk*0.25
ly=0.06
lx=0.3
lsize=0.005 !划分单元网格长度
v=0.004 !焊接速度
tm=lx/v !焊接总时间
tinc=lsize/v !单步时间长度
max_time=1+tm/tinc
max_x=1+lx/lsize
max_y=1+ly/lsize
rectng,0,lx,0,ly
lesize,all,LSIZE
mshape,0,2d
mshkey,1
amesh,all
nsll,s
type,2
esurf
allsel,all
save
finish
!以下为输入高斯移动热源
*dim,flux2,table,max_x,max_y,max_time,x,y,time
*do,k,1,max_time,1
  *do,i,1,max_x,1
   flux2(i,0,k)=(i-1)*lsize
  *enddo
  *do,j,1,max_y,1
   flux2(0,j,k)=(j-1)*lsize
  *enddo
  *do,i,1,max_x,1
    *do,j,1,max_y,1
     xcenter=v*(k-1)*tinc
     ycenter=0
distance=sqrt(((i-1)*lsize-xcenter)**2+((j-1)*lsize-ycenter)**2)
    *if,distance,le,r,then
        flux2(i,j,k)=Qmax/exp(3*distance**2/(r**2))
    *else
        flux2(i,j,k)=0
    *endif
    *enddo
  *enddo
flux2(0,0,k)=(k-1)*tinc
*enddo
finish
/solu
antype,trans
tintp,0.005,,,1,,,   !设置向后积分
kbc,1
timint,off
autots,on
ESEL,S,TYPE,,2
SFE,ALL,,CONV,,100
SFE,ALL,,CONV,2,20    !表面效应单元施加对流系数
ALLSEL,ALL
tref,20
time,1e-6
d,all,temp,20
NSUBST,1
solve               !进行稳态求解,得到初始条件
ddele,all,temp
timint,on
outres,all,all
tsres,erase
kbc,0
esel,s,type,,1
nsle,s
sf,all,hflux,%flux2%
allsel,all
time,73.75
autots,off
deltim,tinc,tinc,tinc
solve
sfdele,all,hflux
time,75
solve
time,725                !冷却过程到725s
autots,0
deltim,25,25,25
solve
finish
/prep7
etchg,tts                !转换单元,进行结构分析
nsel,s,loc,x,0
nsel,r,loc,y,0
d,all,all
allsel,all
dl,1,,symm
finish
/solu
eresx,no                !不选择积分点外推
tref,20
time,1e-6
LDREAD,TEMP,1,1,, ,'Q235','rth',' '
solve
*do,t,1.25,73.75,1.25
time,t
LDREAD,TEMP,,,t, ,'Q235','rth',' '
solve
*enddo
*do,i,1,26,1
time,50+i*25
LDREAD,TEMP,4,i,, ,'Q235','rth',' '
solve
*enddo
finish
发表于 2008-4-16 21:39:12 | 显示全部楼层 来自 四川绵阳
这个例子不是太好
发表于 2008-4-17 12:05:15 | 显示全部楼层 来自 四川成都
这例题就算了吧~
发表于 2008-4-17 12:46:44 | 显示全部楼层 来自 大连理工大学
楼上的两位想必是看过这个例子,说说它的优缺点呗,让大家知道下
发表于 2008-4-22 14:58:55 | 显示全部楼层 来自 山东威海
这个例子虽然实现了应力场模拟的循环,但没有解决如何处理处于熔化状态的单元参与计算的问题,让处于液态的单元按照弹塑性理论计算肯定是不合理的。
发表于 2008-4-22 15:52:42 | 显示全部楼层 来自 辽宁沈阳
我想问问,为什么要
time,1e-6
solve
发表于 2008-4-23 15:19:19 | 显示全部楼层 来自 陕西西安
time,1e-6
是设定的计算时间吧!
发表于 2009-7-17 12:17:58 | 显示全部楼层 来自 上海闵行区
先学习一下再说了,呵呵
GMT+8, 2024-9-20 23:48 , Processed in 0.037586 second(s), 10 queries , Gzip On, MemCache On.
