- 1
- 2008-9-16
做金属压缩模拟的时候出来这些警告和错误,这个static yield stress 在哪里定义呢?
Warnings:
The yield stress is dependent on the temperature/field variables. The current analysis may not be able to proceed if the value of gamma obtained from the curve fit is dependent on the temperature/field variables. However, data from the curve fit may be used to determine an appropriate constant value for gamma which, together with the temperature/field variable-dependent values of c, can then be entered directly in a modified input deck using data type=parameters on the *plastic option.
Errors:
The static yield stress must be defined first
Analysis Input File Processor exited with an error. |
