查看: 194|回复: 6
ANSYS流固耦合,运行时出现错误(附命令流)
发表于 2008-11-22 20:31:33 | 显示全部楼层 |阅读模式 来自 辽宁沈阳
我用的是FSI solver 法,用 SF 及 FSIN 在流体结构界面作两次标记,一次是在界面的流体侧,一次是在界面的固体侧,
但运行时总是出现"ERROR: NO FSIN boundary conditions are defined in the modal."这样的错误。不知道其原因,希望大家有谁明白,解析一下。谢谢!这是流体、固体部分的命令流。
FINISH
/CLEAR
/BATCH,LIST
/PREP7
/UNITS,SI!国际单位制
ET,1,FLUID142
KEYOPT,1,4,1
CYLIND,0,0.015,-0.063,0.063,90,180
CYLIND,0.015,0.029,-0.020,0.020,90,180
CYLIND,0,0.030,-0.063,0.063,90,180
VSBV,3,1
VSBV,4,2
VATT,1
ESIZE,0.005
MSHAPE,1,3D
MSHKEY,0
VMESH,1
!FLUID SIDE
ASEL,S,AREA,,1
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,1
ASEL,S,,,2
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,2
ASEL,S,,,6
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,3
ASEL,S,,,7
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,4
ASEL,S,,,8
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,5
ASEL,S,,,14
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,6
ASEL,S,,,17
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,7
ASEL,S,,,18
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,8
ALLSEL,ALL
DA,14,ALL,0
DA,17,ALL,0
DA,18,ALL,0
/PREP7
ET,2,SOLID45
MP,EX,2,2.1E11
MP,NUXY,2,0.3
CYLIND,0.030,0.032,-0.065,0.065,90,180
CYLIND,0.015,0.030,-0.065,-0.063,90,180
CYLIND,0.015,0.030,0.063,0.065,90,180
VGLUE,2,3
VGLUE,4,6
CYLIND,0,0.015,-0.100,0.100,90,180
VGLUE,3,6
VSEL,S,VOLU,,2
VATT,2
ESIZE,0.02
MSHAPE,1,3D
MSHKEY,0
VMESH,2
VSEL,S,VOLU,,4,5
VATT,2
ESIZE,0.02
MSHAPE,1,3D
MSHKEY,0
VMESH,4,5
VSEL,S,VOLU,,7,8
VATT,2
ESIZE,0.02
MSHAPE,1,3D
MSHKEY,0
VMESH,7,8
ALLSEL,ALL
!SOLID SIDE
ASEL,S,AREA,,41
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,1
ASEL,S,,,42
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,2
ASEL,S,,,34
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,3
ASEL,S,,,35
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,4
ASEL,S,,,36
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,5
ASEL,S,,,12
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,6
ASEL,S,,,16
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,7
ASEL,S,,,23
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,8
ALLSEL,ALL
D,880,ALL,0
D,885,ALL,0
D,890,ALL,0
D,891,ALL,0
FINISH
发表于 2008-11-23 14:01:12 | 显示全部楼层 来自 大连理工大学
错误提示不是说的很清楚吗。
 楼主| 发表于 2008-11-23 14:05:19 | 显示全部楼层 来自 辽宁沈阳
什么很清楚呀?
ASEL,S,AREA,,1
ALLSEL,BELOW,AREA
NSLA,S,1
SF,ALL,FSIN,1
这不是定义了吗?
还需怎样定义呀
 楼主| 发表于 2008-11-23 21:13:58 | 显示全部楼层 来自 辽宁沈阳
此问题解决了
谢谢大家的关注,此问题解决了,但又有了新的问题,没事一步一步解决吧
发表于 2009-3-6 18:57:35 | 显示全部楼层 来自 甘肃兰州
怎么解决的啊?能共享下您的经验吗?
发表于 2009-3-6 21:17:28 | 显示全部楼层 来自 大连理工大学
可否推荐下流固耦合方面的书和资料,最近正要做
发表于 2009-10-30 08:58:50 | 显示全部楼层 来自 武汉大学
我发现,现在怎么都是这样,问题怎么解决的都不传上来看看!
GMT+8, 2024-9-20 21:23 , Processed in 0.043874 second(s), 12 queries , Gzip On, MemCache On.
