- 2008-5-4
/title, Comb Drive Example
/filname,comb,1
/pmeth,on,1
/prep7
! dimensions (microns) / parameters
wf=2 ! Fixed finger width
wm=2 ! Moving finger width
gg=2 ! Gap
tt=40 ! Moving length
t1=4 ! Fixed finger backing
t2=tt ! Moving finger length
hh=10 ! Height
dt=tt/2
V0=10
xx=(2*tt-dt)*2.75
y1=(wm/2)+gg
y2=(wm/2)+gg+wf
x1=tt+t1
! Create Model
cyl4,0,0,xx,0,,360,1
block,-tt,0,y1,y2,0,1
block,(-tt-t1),-tt,-y2,y2,0,1
block,-tt,0,-y1,-y2,0,1
block,-dt,(tt-dt),(-wm/2),(wm/2),0,1
block,(-dt-(gg/2)),(tt-dt+(gg/2)),((-wm/2)-(gg/2)),(wm/2)+(gg/2),0,1
dx=wm*1.1
dy=dx
block,-x1-dx,tt-dt+dx,-y2-dy,y2+dy,0,1
vovlap,all
/com ---------------------------------------
/comVolumeComponent
/com 2,8,9 Fixed Finger
/com 5 Moving Finger
/com 11 Air Layer around Moving Finger
/com 12 Air Layer around the Comb Drive
/com 10 Boundary
! 2D mesh
et,11,200,7 ! Use high order tri mesh element
esize,gg/2
mshape,1 ! Force a traingle mesh
amesh,52 ! Mesh air layer around moving finger
esize,gg
amesh,54 ! Mesh air layer around comb drive
esize,(y2+dy)*5
amesh,50 ! Mesh boundary
! 3D mesh
et,1,128
emunit,epzro,8.854e-6 ! Free space permittivity (uMKSV units)
mp,perx,1,1 ! Set relative permittivity to 1
mat,1 ! 指定单元的材料属性
lsel,s,loc,z,0.5
lesize,all,,,1 ! Set element size in z-direction to 1
lsel,all
type,1
vsel,s,volu,,10,12,1
vsweep,all ! Create wedge volume elements from tri mesh
vsel,all
vsel,s,volu,,10 ! Plot model
eslv,s ! 选择与所选体相关的单元 Selects elements associated with the selected volumes
eplot ! 查看所有单元
allsel
asel,s,loc,z,1 ! Select original areas
aclear,all ! 删除所选面的节点和面单元
etdele,11 ! Remove meshing elements
asel,all
csys,1
nsel,s,loc,x,xx
d,all,VOLT,0 ! Apply volt=0 at outer boundary
nsel,all
csys,0
vsel,s,volu,,5
cm,MFINGER,volu ! 定义组元,将几何元素分组形成组元
asel,s,ext
nsla,s,1 ! Selects those nodes associated with the selected areas
d,all,VOLT,0 ! Apply a zero potential on the moving finger
sf,all,mxwf ! Specifies surface loads on nodes.节点上施加表面载荷
vsel,s,volu,,2
vsel,a,volu,,8,9,1
cm,FFINGER,volu
asel,s,ext
nsla,s,1
d,all,VOLT,V0 ! Apply 10 Volts on the fixed finger
allsel
! p-convergence control
pemopts,5.0,dual ! Select Dual Method with tolerance of 5%
pconv,2,efor,x ! Base convergence on Maxwell forces with tolerance of 2%
/gst,on
save
finish
/solu
eqslv,iccg ! Set ICCG solver
solve
finish
/post1
set,last ! Set the last data step
vsel,s,volu,,11,12
eslv,s
pplot ! Plot the p-levels around the fingers
esel,all
plconv,all ! Plot the convergence curve
etable,fx,fmag,x
etable,fy,fmag,y
etable,fz,fmag,z
ssum
*get,fx,ssum,,item,fx ! Get summed forces
*get,fy,ssum,,item,fy
*get,fz,ssum,,item,fz
/com,Comb Drive Force
*stat,fx
finish
这个是ANSYS help中的关于P方法求梳齿之间的静电力的例子。
我的问题是:(红色标注)
1.为什么要进行2维的网格划分,建模的时候建的空气域也是3D,这里划分的目的是什么....
2.3D划分网络时,为什么删除一些面的节点和面单元。
刚学ANSYS,实在很菜,望高人指点一下,十分感激啊!!! |
