- 2009-4-18
发表于 2011-5-3 23:38:42
来自 上海
INCREMENT 1 STARTS. ATTEMPT NUMBER 1, TIME INCREMENT 1.000E-02
***WARNING: THE SYSTEM MATRIX HAS 58 NEGATIVE EIGENVALUES.
IN AN EIGENVALUE EXTRACTION STEP THE NUMBER OF NEGATIVE EIGENVALUES IS
EQUAL TO THE NUMBER OF EIGENVALUES BELOW THE CURRENT SHIFT POINT.
THIS MAY BE USED TO CHECK THAT EIGENVALUES HAVE NOT BEEN MISSED.
NOTE: THE LANCZOS EIGENSOLVER APPLIES AN INTERNAL SHIFT WHICH WILL
RESULT IN NEGATIVE EIGENVALUES.
IN A DIRECT-SOLUTION STEADY-STATE DYNAMIC ANALYSIS, NEGATIVE
EIGENVALUES ARE EXPECTED. A STATIC ANALYSIS CAN BE USED TO VERIFY THAT THE SYSTEM IS STABLE.
IN OTHER CASES, NEGATIVE EIGENVALUES MEAN THAT THE SYSTEM MATRIX IS NOT
POSITIVE DEFINITE:
FOR EXAMPLE, A BIFURCATION (BUCKLING) LOAD MAY HAVE BEEN EXCEEDED.
NEGATIVE EIGENVALUES MAY ALSO OCCUR IF QUADRATIC ELEMENTS ARE
USED TO DEFINE CONTACT SURFACES.
***WARNING: THE INCREMENTAL ROTATION AT THE FIRST NODE OF THE CONNECTOR
ELEMENT NUMBER 2764 IS VERY LARGE. THIS MAY LEAD TO INCORRECT
INCREMENTAL ROTATION UPDATE.
ELEMENT NUMBER 2765 IS VERY LARGE. THIS MAY LEAD TO INCORRECT
ELEMENT NUMBER 2766 IS VERY LARGE. THIS MAY LEAD TO INCORRECT
ELEMENT NUMBER 2767 IS VERY LARGE. THIS MAY LEAD TO INCORRECT
ELEMENT NUMBER 2805 IS VERY LARGE. THIS MAY LEAD TO INCORRECT
ELEMENT NUMBER 2806 IS VERY LARGE. THIS MAY LEAD TO INCORRECT
ELEMENT NUMBER 2807 IS VERY LARGE. THIS MAY LEAD TO INCORRECT
ELEMENT NUMBER 2808 IS VERY LARGE. THIS MAY LEAD TO INCORRECT
ELEMENT NUMBER 2817 IS VERY LARGE. THIS MAY LEAD TO INCORRECT
ELEMENT NUMBER 2818 IS VERY LARGE. THIS MAY LEAD TO INCORRECT
ELEMENT NUMBER 2819 IS VERY LARGE. THIS MAY LEAD TO INCORRECT
ELEMENT NUMBER 2821 IS VERY LARGE. THIS MAY LEAD TO INCORRECT
CONVERGENCE CHECKS FOR EQUILIBRIUM ITERATION 1
AVERAGE FORCE 1.316E+03 TIME AVG. FORCE 1.316E+03
LARGEST RESIDUAL FORCE -3.610E+04 AT NODE 7487 DOF 2
LARGEST INCREMENT OF DISP. 24.6 AT NODE 7573 DOF 1
LARGEST CORRECTION TO DISP. 24.6 AT NODE 7573 DOF 1
FORCE EQUILIBRIUM NOT ACHIEVED WITHIN TOLERANCE.
AVERAGE MOMENT 4.809E+05 TIME AVG. MOMENT 4.809E+05
LARGEST RESIDUAL MOMENT 1.167E+05 AT NODE 7500 DOF 6
LARGEST INCREMENT OF ROTATION 2.88 AT NODE 3614 DOF 6
LARGEST CORRECTION TO ROTATION 2.88 AT NODE 3614 DOF 6
MOMENT EQUILIBRIUM NOT ACHIEVED WITHIN TOLERANCE.
麻烦斑竹大人帮忙看看,搞了好久也没办法解决,一开始就不收敛,谢谢了!…^_^ |
