查看: 63|回复: 1
Matlab下如何输出.mat格式的文件
发表于 2009-8-4 10:55:28 | 显示全部楼层 |阅读模式 来自 广东广州
各位请教一下!如何把拟合出来的曲线输入保存,输出.mat格式的文件!不胜感激!
发表于 2009-8-4 16:50:51 | 显示全部楼层 来自 黑龙江哈尔滨
help save
SAVE Save workspace variables to disk.
  SAVE FILENAME saves all workspace variables to the binary "MAT-file"
  named FILENAME.mat.  The data may be retrieved with LOAD.  If FILENAME
  has no extension, .mat is assumed.
MAT Options:
   SAVE ...  -MAT     saves in MAT format regardless of extension.
   SAVE ...  -V4      saves a MAT-file that MATLAB 4 can LOAD.
   SAVE ...  -APPEND  adds the variables to an existing file (MAT-file only).
save 命令应该可以 O(∩_∩)O~
GMT+8, 2024-10-7 07:30 , Processed in 0.036694 second(s), 17 queries , Gzip On, MemCache On.
