- 2006-5-21
The modified tetrahedral elements are incompatible with the regular triangular prism elements if they share the same nodes
For *tie pair (assembly__t0_part-1-1_s-assembly__t0_part-1-1_m), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Slave surface assembly__t0_part-1-1_sn is a node-based surface used with surface to surface approach. In order to obtain improved stress accuracy with this approach, an element-based surface should be used instead.
Please make sure that the mesh density of the slave surface in the tie pair (assembly__t0_part-1-1_sn,assembly__t0_part-1-1_m) is finer than the master surface. The analysis may run slower, may yield inaccurate results, and may require more memory if this is not the case.
For *tie pair (assembly__t0_part-1-1_sn-assembly__t0_part-1-1_m), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Slave surface assembly__t1_part-1-1_sn is a node-based surface used with surface to surface approach. In order to obtain improved stress accuracy with this approach, an element-based surface should be used instead. |
