查看: 266|回复: 1
【讨论】how to use COMMAND in CAE?
发表于 2003-7-14 09:47:03 | 显示全部楼层 |阅读模式 来自 美国
I tried to use command window in CAE, but always can not go through the correct format, any one can help me on that?
e.g. in ABAQUS Example Problems Manual ->
Extracting two-dimensional profiles and remeshing using ABAQUS/CAE
I tried to follow the instruction and built my own command line like
PartFromOdb(name='CH_remesh',fileName='071003_rubber.odb',instance='CH',shape=DEFORMED,step=1)
but there is always error info like "there is no variable named 'PartFromOdb'" or "SyntaxError: can't assign to literal"
Why wrong? and what's the right format for command? Thanks.
发表于 2003-7-14 10:47:03 | 显示全部楼层 来自 日本
回复: 【讨论】how to use COMMAND in CAE?
I have never used command in CAE, so excuse me.
GMT+8, 2024-7-1 23:11 , Processed in 0.030978 second(s), 14 queries , Gzip On, MemCache On.
