- 6
- 2008-11-6
楼主 |
发表于 2010-6-23 10:24:16
来自 湖北武汉
接着就是材料定义部分。这部分我尝试过四个混凝土本构
因为还是在试算阶段,我将钢筋设置为弹性材料,混凝土为损伤塑性。
第一个混凝土的本构是abaqus提供的。如下:
*Concrete Damaged Plasticity
15., 0.1, 1.16, 0.6667, 0.
*Concrete Compression Hardening
2.598e+07, 0.
3.1593e+07, 0.0004
3.4298e+07, 0.0008
3.5e+07, 0.0012
3.4362e+07, 0.0016
3.2859e+07, 0.002
3.0835e+07, 0.0024
2.3696e+07, 0.0036
1.6113e+07, 0.005
3.194e+06, 0.01
*Concrete Tension Stiffening
3.291e+06, 0.
2.693e+06, 0.0001
2.058e+06, 0.0003
1.775e+06, 0.0004
1.479e+06, 0.0005
991000., 0.0008
664000., 0.001
298000., 0.002
135000., 0.003
74000., 0.005
第二种为 c50的本构,是一个网友提供的,数据不太方便发布
第三种是C40的本构
数据如下:
*Material,name=concrete
*Elastic
3.4e+04, 0.2
30., 0.1, 1.16, 0.6667, 0.!
30, 0.
39.6, 0.0005
39.6, 0.001
15, 0.007
9, 0.02
3.5, 0.
1.2, 0.001
0.68, 0.01
第四种为:
*MATERIAL, NAME=C60
*ELASTIC
3.60E10,0.3
*DENSITY
2500.
*CONCRETE DAMAGED PLASTICITY
35.,0.1,1.2,0.85,0.
*CONCRETE COMPRESSION HARDENING
10.80000E6,0.00000
21.24139E6,0.00030
28.84499E6,0.00060
30.90988E6,0.00070
32.73428E6,0.00080
34.31478E6,0.00090
35.64800E6,0.00100
36.73052E6,0.00110
37.55895E6,0.00120
38.12988E6,0.00130
38.43992E6,0.00140
38.48567E6,0.00150
38.12922E6,0.00160
37.43699E6,0.00170
36.48357E6,0.00180
35.34608E6,0.00190
34.09038E6,0.00200
32.76977E6,0.00210
31.42549E6,0.00220
30.08815E6,0.00230
28.77951E6,0.00240
27.51431E6,0.00250
26.30190E6,0.00260
25.14760E6,0.00270
24.05383E6,0.00280
23.02091E6,0.00290
22.04777E6,0.00300
21.13239E6,0.00310
16.69329E6,0.00370
12.06599E6,0.00470
9.322450E6,0.00570
7.548990E6,0.00670
6.322140E6,0.00770
5.428350E6,0.00870
4.750640E6,0.00970
4.220310E6,0.01070
3.794640E6,0.01170
3.445790E6,0.01270
3.154910E6,0.01370
2.908780E6,0.01470
2.697920E6,0.01570
2.515290E6,0.01670
2.355630E6,0.01770
2.214880E6,0.01870
2.089900E6,0.01970
*CONCRETE TENSION STIFFENING
0.36000E6,0.00000
0.59774E6,0.00001
0.89645E6,0.00002
1.19448E6,0.00003
1.49043E6,0.00004
1.78143E6,0.00005
2.06228E6,0.00006
2.32447E6,0.00007
2.55497E6,0.00008
2.73488E6,0.00009
2.83784E6,0.00010
2.81012E6,0.00011
2.65078E6,0.00012
2.45231E6,0.00013
2.25249E6,0.00014
2.06683E6,0.00015
1.90041E6,0.00016
1.75361E6,0.00017
1.62491E6,0.00018
1.51215E6,0.00019
1.41315E6,0.00020
1.32592E6,0.00021
1.24872E6,0.00022
1.18008E6,0.00023
1.11875E6,0.00024
1.06370E6,0.00025
1.01406E6,0.00026
0.96910E6,0.00027
0.92822E6,0.00028
0.89090E6,0.00029
0.64307E6,0.00039
0.51131E6,0.00049
0.42915E6,0.00059
0.37267E6,0.00069
0.33122E6,0.00079
0.29936E6,0.00089
0.27402E6,0.00099
0.25332E6,0.00109
0.23604E6,0.00119
0.22137E6,0.00129
0.20874E6,0.00139
0.19773E6,0.00149
0.18803E6,0.00159
0.17942E6,0.00169
0.17171E6,0.00179
0.16476E6,0.00189
0.15845E6,0.00199
*CONCRETE COMPRESSION DAMAGE, TENSION RECOVERY=1.
0.00000,0.00000
0.07707,0.00030
0.12437,0.00060
0.14008,0.00070
0.15625,0.00080
0.17290,0.00090
0.19006,0.00100
0.20776,0.00110
0.22604,0.00120
0.24494,0.00130
0.26451,0.00140
0.28481,0.00150
0.30712,0.00160
0.33082,0.00170
0.35532,0.00180
0.38004,0.00190
0.40453,0.00200
0.42847,0.00210
0.45162,0.00220
0.47384,0.00230
0.49503,0.00240
0.51515,0.00250
0.53420,0.00260
0.55219,0.00270
0.56916,0.00280
0.58515,0.00290
0.60021,0.00300
0.61440,0.00310
0.68403,0.00370
0.75973,0.00470
0.80720,0.00570
0.83938,0.00670
0.86250,0.00770
0.87988,0.00870
0.89339,0.00970
0.90420,0.01070
0.91302,0.01170
0.92037,0.01270
0.92658,0.01370
0.93189,0.01470
0.93649,0.01570
0.94051,0.01670
0.94405,0.01770
0.94719,0.01870
0.95000,0.01970
*CONCRETE TENSION DAMAGE
0.00000,0.00000
0.00001,0.00001
0.00010,0.00002
0.00044,0.00003
0.00133,0.00004
0.00331,0.00005
0.00717,0.00006
0.01402,0.00007
0.02541,0.00008
0.04342,0.00009
0.07093,0.00010
0.11484,0.00011
0.17402,0.00012
0.23445,0.00013
0.29118,0.00014
0.34258,0.00015
0.38842,0.00016
0.42907,0.00017
0.46508,0.00018
0.49704,0.00019
0.52550,0.00020
0.55095,0.00021
0.57379,0.00022
0.59440,0.00023
0.61306,0.00024
0.63002,0.00025
0.64551,0.00026
0.65970,0.00027
0.67275,0.00028
0.68479,0.00029
0.76807,0.00039
0.81503,0.00049
0.84530,0.00059
0.86654,0.00069
0.88230,0.00079
0.89451,0.00089
0.90425,0.00099
0.91222,0.00109
0.91888,0.00119
0.92452,0.00129
0.92937,0.00139
0.93359,0.00149
0.93729,0.00159
0.94058,0.00169
0.94351,0.00179
0.94614,0.00189
0.94851,0.00199 |
