- 2010-3-16
流化床2D模拟,先是画了一个矩形,然后设置边界条件,进口inlet;出口outlet;其余为wall;计算提示如下错误:
| ERROR #002100048 has occurred in subroutine SU_BNEXT. |
| Message: |
| All vertices for a fluid domain lie on boundaries. This is |
| considered to be a fatal error because control volume gradients |
| cannot be calculated, leading to serious discretization error. |
| A common cause for this error is a mesh which is only one |
| element thick, without symmetry or 1:1 periodicity on the lateral |
| boundaries. If you have this situation, and the domain is |
| two-dimensional, please change the lateral boundary conditions |
| to symmetry or 1:1 periodicity. Alternatively, for |
| three-dimensional simulations, please ensure that your mesh |
| has at least two elements across.
貌似是要设置对称性边界条件,把除进口和出口外的所有面都设置成symmetry么? |
