What kind of software you are using? The tolerance is 0.01. Is it based on energy, displacement or nodal force? For nonlinear analysis, you cannot just run it once in the hope you can get everything. You might play with the number of load steps and tolerance to see if there is significant change in the final results. If there isn't, you are fine.
