查看: 416|回复: 7
[网格划分] hm里的显示精度!
发表于 2010-9-21 17:39:12 | 显示全部楼层 |阅读模式 来自 北京
问一下,hm的显示精度可调不?圆的显示很不光顺,有折线!
发表于 2010-9-23 15:18:05 | 显示全部楼层 来自 上海
HW11.0有这个功能~
发表于 2010-10-8 15:41:21 | 显示全部楼层 来自 广东深圳
你有11.0用过吗?
发表于 2010-10-10 10:51:02 | 显示全部楼层 来自 上海
对于一般用户来说没有这个必要!
发表于 2010-10-12 17:47:35 | 显示全部楼层 来自 湖北武汉
天哪,10还没用熟呢
发表于 2010-10-12 19:12:52 | 显示全部楼层 来自 北京
C:\Altairwin64\hw10.0\hm\bin\win64\hm.cfg
调整配置文件的这两项:
Shaded geometry visualization sometimes does not follow the actual geometry;?
this usually occurs in models that are large in one direction, but small in another direction.?
Modify the shadingquality(N) command (where N is a number between 1 and 10; 5 is the default).
Raising or decreasing shading quality by 1 roughly doubles or halves the quality.
Note, however, that N does not need to be an integer梔ecimal values are acceptable
    *shadingquality(5)
The following command controls how surface edges are plotted.  The value can be either 1 or 0.
For default value 1 discretization of edge geometry is synchronized with surface faceting
(see previous command). The value of 0 provides finer edge representation (for default
faceting density - value 5 in previous command).
    *linefacetmatch(1)
发表于 2010-12-17 10:08:28 | 显示全部楼层 来自 北京
这个好,夕夕谢lz
发表于 2011-1-17 20:45:05 | 显示全部楼层 来自 广东江门
同上,十点零还没有用熟呢。
GMT+8, 2024-5-12 18:26 , Processed in 0.039667 second(s), 14 queries , Gzip On, MemCache On.
