COULDN'T FIND A CORRESPONDING REGION IN THE PRIOR MODEL FOR PART
INSTANCE DOWNER-1, ELEMENT 28, MATERIAL POINT 4. ALL
SOLUTION QUANTITIES ARE SET TO ZERO.
***WARNING: ELEMENT 874 IN PART INSTANCE PART-1-2 IS TOO DISTORTED TO
ACCURATELY MAP FROM. THE DISTORTED CONFIGURATION OF THIS ELEMENT
MAY EXPLAIN EARLIER WARNING MESSAGES INDICATING FAILURES TO LOCATE
POINTS IN THE PRIOR MODEL. CONSIDER REMESHING EARLIER.
