查看: 386|回复: 1
[警告错误信息] mpi路径设置
发表于 2010-12-22 13:03:36 | 显示全部楼层 |阅读模式 来自 北京
采用abaqus6.10提交计算时,出现这样的错误:
MPI launcher 'C:\Program Files\Hewlett-Packard\HP-MPI\bin\mpirun.exe' not found.
If an appropriate release of MPI has been installed, use the mp_mpirun_path Abaqus environment variable to specify the correct path.  A MPI installation is required for serial and parallel execution of CFD analyses.
我的mpi安装路径是E:\Program Files\Hewlett-Packard\HP-MPI\bin
请问如何修改呢?
 楼主| 发表于 2010-12-22 13:36:34 | 显示全部楼层 来自 北京
nnd,万佛朝宗了。。。把mpi卸载了,装在C盘可以算了=。=
GMT+8, 2026-1-2 20:06 , Processed in 0.037671 second(s), 13 queries , Gzip On, MemCache On.
