- 2010-10-4
发表于 2011-1-5 07:14:14
来自 美国
I thought above explanation is not good enough. For example, the linear displacement element can pass patch test. That means it exactly recover the linear displacement filed. In another word, the numerical solution is exactly same as real displacement. For cantilever beam bending, it happens as what you said. But, many factors can effect the stiffness of a element such as interpolation or integration method. Usually, the full integration displacement element is stiffer than reduced integration element. If you consider meshfree method or particle method too, you may find that your observation might not be always true. |
