- 46
- 2007-4-28
发表于 2011-6-15 16:51:34
来自 河北廊坊
- clear;clc;close all
- s = 0.121;
- p = 0.126;
- v = 2.87;
- f = @(x) (s./(x.*sqrt(pi).*exp(x.^2).*erf(x)) + p./(v.*x.*sqrt(pi).*exp(v.*x.^2).*erfc(v.*x)) - 1);
- figure(1)
- fplot(f,[-0.5,-0.15]);
- figure(2)
- fplot(f,[0.2,0.5]);
- la = fsolve(f,[-0.2,0.2])
复制代码
- Equation solved.
- fsolve completed because the vector of function values is near zero
- as measured by the default value of the function tolerance, and
- the problem appears regular as measured by the gradient.
- <stopping criteria details>
- la =
- -0.2352 0.2817
复制代码 |
