- 1
- 2010-4-27
我想输出若干frame下的实体节点位移和应力,命令如下:
session.writeFieldReport(fileName='0.rpt', append=ON, sortItem='Node Label', odb=odb, step=5, frame=105, outputPosition=NODAL, variable=(('U', NODAL, ((COMPONENT, 'U1'), (COMPONENT, 'U2'), (COMPONENT, 'U3'), )), ('S', INTEGRATION_POINT, ((COMPONENT, 'S11'), (COMPONENT, 'S22'), (COMPONENT, 'S33'),(COMPONENT, 'S12'), (COMPONENT, 'S13'), (COMPONENT, 'S23'), )), ), numericForm=COMPLEX_MAGNITUDE)
为什么结果对于应力只有S11、S22、S33,而且还输出两遍,而没有剪应力S12、S13、S23?
结果如下:
Field Output Report, written Thu Aug 04 15:05:34 2011
Source 1
ODB: f:/Temp-abaqus/8-1/7750/7750direct.odb
Step: Step-6
Frame: Increment 1: Frequency = 20.00
Complex: Magnitude
Loc 1 : Nodal values from source 1
Loc 4 : Nodal values at shell < BAN > < 5 section points > from source 1 : SNEG, (fraction = -1.0)
Loc 5 : Nodal values at shell < BAN > < 5 section points > from source 1 : SPOS, (fraction = 1.0)
Output sorted by column "Node Label".
Field Output reported at nodes for region: PART-1-1.Region_7
Computation algorithm: EXTRAPOLATE_COMPUTE_AVERAGE
Averaged at nodes
Averaging regions: ODB_REGIONS
Node U.U1 U.U2 U.U3 S.S11 S.S11 S.S22 S.S22 S.S33 S.S33
Label @Loc 1 @Loc 1 @Loc 1 @Loc 4 @Loc 5 @Loc 4 @Loc 5 @Loc 4 @Loc 5
1 3.82729E-39 48.1559E-39 57.2969E-39 -175.064E-06 -175.064E-06 1.76513E-03 1.76513E-03 -2.15146E-03 -2.15146E-03
2 213.702E-12 12.0676E-09 45.6195E-09 -14.0872E-06 -14.0872E-06 -9.49045E-06 -9.49045E-06 -24.6515E-06 -24.6515E-06
3 6.34348E-09 -119.536E-09 -26.1499E-09 130.65E-06 130.65E-06 286.815E-06 286.815E-06 -357.789E-06 -357.789E-06 |
