- 39
- 2006-1-20
发表于 2007-3-25 18:26:38
来自 黑龙江哈尔滨
回复 #1 zhanjun131 的帖子
1.原因:Boolean operations and other solid modeling operations can be unreliable, either failing to work or corrupting/contaminating the database. You should SAVE a copy of your database before a Boolean operation in order to cleanly recover from a failure.
2.办法:
If the geometry is unworkable (no Boolean will work or it cannot be meshed), or if you have encountered a “database corruption” (or contamination) message, then as a work-around use CDWRITE to write out the geometry (CDWRITE,COMB) using the ANF option (CDOPT,ANF) and CDREAD to read it back in (after exiting and re-entering ANSYS) to obtain clean geometry. |
