- 2008-3-22
发表于 2008-3-22 10:43:15
来自 江西南昌
isight本身的帮助有这个。
To set up the add-in:
1 Open Microsoft Excel; then, select Add-Ins... from the Tools menu. The Add-Ins dialog box appears.
2 Perform one of the following steps, based on your Excel setup:
• If you received an error message when you first opened Excel, click the iSight entry in the Add-Ins dialog box. A message appears, asking you if you want to delete the old add-in. Proceed to step 3 .
• If you did not receive an error message when you first opened Excel, proceed to step 7 .
3 Click Yes. The add-in is removed from the list.
4 Click OK to close the Add-Ins dialog box; then, close Excel.
Important: You must close the Add-Ins dialog box and close Excel. If you do not close Excel, the error message will continue to appear when you start Excel.
5 Restart Excel. The error message should no longer appear at startup.
6 Select Add-Ins... from the Tools menu. The Add-Ins dialog box appears.
7 Click the Browse... button; then, navigate to the following directory for the current version of iSIGHT:
<isight_install_directory>\custom\system\
8 Verify that the file iSIGHT.xla is highlighted; then, click OK. You are returned to the Add-Ins dialog box, where the add-in Isight now appears, with a check mark next to it.
9 Click OK. The add-in can now be accessed.
10 Verify the add-in setup by clicking the Excel Tools menu. The option iSIGHT... should now appear on the menu.
For information on using the Excel Interface, see Using the Interface in Excel. |
