hi
i tried your advice it seemed worked well at first but now i have another problem. Let me explain the whole process firstly. There will be two container and two pipes in the model. Pipes and containers are connected each other. In a nutshell, two containers connected with two pipes. So there must be common elements with containers and pipes. I defined them as holes which has to be in the container coupling and pipe coupling. Now i have four coupling surface. My dytran code does not give the "interacting coupling problem" anymore. But i cant see the flow between coupling surfaces, especially form the first container to the pipe.
$-----------------------------Domain 1------------------------------
PEULER1,450,,MMHYDRO,100
MESH,450,ADAPT,8.,8.,8.,,,,+
+,,,,,,,EULER,450
COUPLE,450,101,OUTSIDE,,,,,,+
+,,450
SURFACE,101,,PROP,101
SET1,101,18,19,20,43,THRU,46
$---------Euler initial condition---------------
$----------------------------------Domain 4-----------------------------
PEULER1,480,,MMHYDRO,400
MESH,480,ADAPT,8.,8.,8.,,,,+
+,,,,,,,EULER,480
COUPLE,480,401,OUTSIDE,,,44,,,+
+,,480
SURFACE,401,,PROP,401
SET1,401,21,22,1,47,THRU,50
COUPOR,21,44,21,PORFLOW,21,,1.0
PORFLOW,21,,XVEL,0.,DENSITY,8.5425E-7,FLOW,IN,+
+,YVEL,-7000.,ZVEL,-7000.,MATERIAL,2,,,+
+,SIE,0
SUBSURF,21,401,PROP,451
SET1,451,47
$-----------------------------Domain 2------------------------------
PEULER1,460,,MMHYDRO,200
MESH,460,ADAPT,8.,8.,8.,,,,+
+,,,,,,,EULER,460
COUPLE,460,201,OUTSIDE,,,22,,,+
+,,460
SURFACE,201,,PROP,201
SET1,201,1,THRU,20
COUPOR,460,22,460,PORFLCPL,460,,1.0
PORFLCPL,460,,,BOTH,450
SUBSURF,460,201,PROP,250
SET1,250,20
COUPOR,461,22,460,PORFLCPL,461,,1.0
PORFLCPL,461,,,BOTH,480
SUBSURF,461,201,PROP,251
SET1,251,1
$-----------------------------Domain 3------------------------------
PEULER1,470,,MMHYDRO,300
MESH,470,ADAPT,8.,8.,8.,,,,+
+,,,,,,,EULER,470
COUPLE,470,301,OUTSIDE,,,33,,,+
+,,470
SURFACE,301,,PROP,301
SET1,301,21,THRU,44
$COUPOR,470,33,470,PORFLCPL,470,,1.0
$PORFLCPL,470,,,BOTH,480
$SUBSURF,470,301,PROP,351
$SET1,351,21
PORFLCPL,470,,,BOTH,450
SUBSURF,470,301,PROP,350
SET1,350,44
COUPOR,31,33,31,PORFLOW,31,,1.0
PORFLOW,31,,MATERIAL,1,DENSITY,1.29e-9,SIE,1.938e+11,+
+,PRESSURE,100.
SUBSURF,31,301,PROP,351
SET1,351,21
This is my dytran code, i did not give the initial conditions. Domain 1 and domain 4 are containers. domain2 and domain3 are pipes. I tried to create a hole at property 1 but it didnt worked up to now. I cant see the flow from the domain4 to domain2. What is the reason? Thanks... |
